Best Value Palit GeForce GT 640 2GB PCI-Express 3.0 HDMI
Quicklinx: 84BZWS00 Mfr#: NEAT6400HD41-1070F
  • High-Definition Multimedia Interface (HDMI)
Palit GeForce GT 640 2GB Features
  • Kepler Architecture
  • 28nm - better performance and low power
  • PCI Express 3.0
  • 5X Faster Photo Editing
  • 9X Faster Video Creation
  • 2X Faster Web Browsing
  • 7X Faster Gameplay
Key GPU Features
  • Microsoft DirectX11 support
  • Blu-Ray 3D support
  • NVIDIA CUDA technology with CUDA C/C++
  • DirectCompute 5.0 and OpenCL support
  • NVIDIA PhysX technology
  • NVIDIA FXAA technology
  • NVIDIA Adaptive Vertical Sync
  • TrueHD and DTS-HD Audio Bitstreaming Support
  • PCI Express 3.0 support
  • Dual-link DVI connector
  • One HDMI 1.4a connector
  • OpenGL 4.2 support
Minimum System Requirements
  • PCI Express-compliant motherboard with one dualwidth x16 graphics slot
  • Minimum 350W or greater system power supply (with a minimum 12V current rating of 20A)
  • Supported Operating Systems: Windows 7, Windows Vista, Windows XP
Specification
  • Output Support: VGA, HDMI, DVI-D
  • Process Technology: 28nm
  • Processor Cores: 384 cores
  • Memory: 2GB
  • Memory Interface: 128bit
  • DRAM Type: DDR3
  • Core Clock: 900MHz
  • Memory Clock: 891MHz (DDR1782MHz)
  • Memory Bandwidth: 28.51 (GB/sec)
  • Power Consumption: 65W
  • PCB: 150mm(L) x 69mm(W)
  • Cooler :2 slot
  • Bracket: 2 slot
Graphics Processor Manufacturer
NVIDIA
Graphics Processor
NVIDIA GeForce GT 640
PCI Express 3.0
Memory Size
2 GB
Digital Output
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Core Clock
900 MHz
Resources
The following resources are available for the Best Value Palit GeForce GT 640 2GB PCI-Express 3.0 HDMI
