Best Value OEM-511 Micro ATX Case USB 3.0 & 500W PSU
Quicklinx: B16WWS00 Mfr#: OEM-511
511 Chassis: New Micro ATX Tower chassis for system building meeting the latest thermal requirements for dual core cpu's
  • Piano finish
  • 500w 12cm Fan PSU
  • USB 3.0
  • Screwless chassis with clip and lock design
  • 1 x Steathed DVD cover ; 1 x 3.5"
  • USB 3.0 x 1 , USB 2.0 x 1 , HD Audio to front panel
  • Vented for dual core systems to side
  • Excellent heat dissipation capabilities
  • Riveted SECC metal frame
  • ABS Plastic Front panel
  • Removable side panel with grips for easy removal and maintenance
  • Side Panels with filter for best ventilation
  • Expansion Slots 4
  • For Micro ATX boards
  • Dimensions W180; D 390mm; H 365mm
  • ROHS Compliant
  • Power cable not included
Spec
  • Manufacturer:OEM
  • Audio Output: Yes - HD Audio
  • I/O Ports: 1 x USB 3.0 , 1 x USB 2.0
  • Colour: Black
  • Weight: 5000g
  • Form Factor: Micro ATX
  • Supported Motherboard Form Factor: mATX
  • Type: PC
  • Material: SECC metal
  • Ventilation Fans: 1 x 120mm fan space to front , 1 x 120mm rear fan space
  • External Drive bays: 1 x 5.25
  • Internal Drive bays : 1 x 3.5 , 2 x 3.5 HDD
Case Form Factor
Mid tower
Micro ATX
Power Supply
500 Watt
