Best Value LiteOn 24x Int. DVDRW Black SATA + S/W
Quicklinx: 6M84WS00 Mfr#: IHAS124-19
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
Lite-On 24x internal DVD writers offer the fastest DVD recording speed among other similar devices. With these Lite-On DVD writer users can create and share their home videos, back-up critical information, create digital photo albums, watch DVD movies and so much more. Versatility is the key! The fully featured Lite-On iHAS324 drive comes with the latest optical storage technologies.
Key Features
  • 24X powered by SmartWrite
  • Super AllWrite
  • Serial ATA (SATA) connectivity
  • Includes Nero 8 Essentials software
SmartWrite can overspeed certain 16X DVD±R media to a maximum of 24X
With 24X DVD±R writing speeds, Lite-On offers the fastest DVD±R writing possible
Always burn with the highest speed and best quality. SmartWrite optimizes the writing strategy for each particular session and automatically memorizes this for future sessions
Super AllWrite
Super AllWrite is the compatibility standard from Lite-On to offer the ability to read, write and re-write to any disc format on the market,
Use your DVD writer for any purpose with the media you desire (including CD-R, CD±RW, DVD±R, DVD±RW, DVD±R DL, DVD-RAM format discs)
Purchase your media without hassle; you no longer have to worry about compatibility
Higher transfer rates with SATA connection (compared to PATA)
Future proof; compatibility with the latest motherboards
Better airflow in PC casings due to smaller cable and plug sizes
SATA supports "hot swap" (must be supported by your motherboard)
Please note this is Revision C
LiteOn iHAS124 - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA - internal
DVD±RW (±R DL) / DVD-RAM drive - internal
Serial ATA
14.6 cm x 17 cm x 4.1 cm
0.9 kg
Optical Storage
DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H
Read Speed
48x (CD) / 16x (DVD)
Write Speed
48x (CD) / 24x (DVD±R) /12x (DVD±R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Buffer Underrun Protection
SMART Burn
Media Load Type
Tray
Microsoft Certification
Compatible with Windows 7
Serial ATA
14.6 cm
17 cm
4.1 cm
0.9 kg
Optical Storage
Read Speed
Write Speed
Supported Recording Modes
Multisession, disc-at-once, track-at-once, packet writing, session-at-once, restricted overwrite, random access write, incremental recording, sequential write, Layer Jump Recording (LJR)
Supported Media Formats
CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM, CD+G (Karaoke CD)
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Media Load Type
Tray
Access Time
160 ms (DVD), 140 ms (CD)
SMART Burn
SMART-X, Auto Balance System (ABS)
Video CD
1 x Serial ATA-150 - 7 pin Serial ATA
Compatible Bay
1 x 5.25" x 1/2H - front accessible
MTBF
70,000 hour(s)
Package Type
OEM
Microsoft Windows Vista / 2000 / XP
System Requirements Details
Pentium 4 - 1.3 GHz - RAM: 128 MB - HDD: 650 MB
5 °C
50 °C
15 - 80%
