Best Value Freecom Hard Drive Dock Pro
Quicklinx: 6M9FWS00 Mfr#: 33708
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
Freecom Hard Drive Dock Pro. External Docking Station for 2.5" & 3.5" Internal SATA & PATA (IDE) Hard Drives.
Key Features
  • Perfectly suited for both professional and home use
  • No cooling fan ensures quiet operation
  • Retrieve data from an old internal hard drive
  • Quickly erase data or reformat an internal hard drive
  • Suitable for both SATA and PATA Hard Drives
Give your old PATA/IDE hard drive a new lease of life! With the Hard Drive Dock Pro, which holds both contemporary SATA drives as well as the older PATA/IDE drives, you can now easily connect and use your old IDE hard drive again. Just connect it to the dock, and you instantly can access the drive via USB 2.0. It is ideal for quickly retrieving old files and programs.
Have an older hard drive lying around after a system upgrade? Are you a system administrator who needs to install multiple hard drives? Looking for a good solution to easily connect and use your internal hard drive? Look no further - the Freecom Hard Drive Dock Pro provides the solution: a docking station that turns any internal 2.5" and 3.5" SATA and PATA hard drive into an external drive. Simply click your internal hard drive in the dock, and it instantly becomes available to you, it will show up as an external USB 2.0 device on your computer. No easier way to install and use an internal drive - ideal for temporary use of your (old) internal hard drive. An intelligent and convenient storage solution - by Freecom.
Freecom Hard Drive Dock Pro - HDD docking station - ATA / SATA 3Gb/s - USB 2.0
HDD docking station - external
Bays
1
Bus Type
USB 2.0
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
ATA / SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
13.6 cm x 9.5 cm x 7.7 cm
Bays
1
2.5", 3.5"
Host Bus
USB 2.0
Storage Controller
ATA / SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Bays
1 x SATA 3Gb/s , 1 x ATA
1 x USB 2.0
Software Included
Drivers & Utilities
13.6 cm
9.5 cm
7.7 cm
