The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
Compro C100 Digital PCI Interface Analog/Audio Capture Card with Ulead VideoStudio 11 SE & Ulead DVD MovieFactory 5 SE
Compro VideoMate C100 capture card is an PCI 2.1 interface analog video/audio input and capture device that can convert analog video/audio from your DV camcorder, V8, VHS tapes, DVD recorder, VCD Players, and camera. Easily plugs into any PCI 2.1 slots on PC, the Compro VideoMate C100 imports all your TV recordings?home video recordings?favorite videotapes and any other video/audio collections into your hard disk.
For creating your own movie and DVD titles, VideoMate C100 is bundled with the powerful video editing and DVD authoring software, the Ulead VideoStudio 11 SE and DVD MovieFactory 5 SE. The all-new Ulead VideoStudio 11 SE provides an easy-to-use and friendly video editing interface and the movie wizard can help you to create movie quickly. Multi-Trim Editor feature to extract multiple segments from video for further editing. AccuCut Editing with Timeline zoom let you quickly find the exact frame to start trimming. To improve the video quality, VideoStudio 11 SE also provide the useful Auto Color & Tone correction, DeBlock filter, DeSnow filter, and Anti-Shack filter to easily fix common video problems. The Ulead DVD MovieFactory 5 SE provides a one-step DVD creation solution; you can make your own DVD or VCD by selecting theme style, picking customizable effects, using quick way to trim the long video clips and burning video from various sources to DVDs without occupying the hard disk space. The Compro Videomate C100 is coupled with the Ulead VideoStudio 11 SE and Ulead DVD MovieFactory 5 SE to simplify the digitize process and keep your happy memories forever.
- Capture video and save to hard disk or directly burn to VCD, DVD
- High-speed PCI 2.x interface for desktop PC
- Provide S-Video, composite video, and stereo audio input
- Bundled with Ulead VideoStudio 11 SE and Ulead DVD MovieFactory 5 SE to create your own movies with ease.
Hardware
- Built-in video/audio processing chip and PCI chip
- PCI 2.x interface for plug & play
- Support PAL/NTSC video input
- Provide S-video, composite video and stereo audio input ( RCA jack)
- Dimensions : 12 x 10 cm
Software
Ulead VideoStudio 11 SE is an easy-to-use video editing and DVD authoring software that lets anyone create and share great-looking videos, slideshows and DVDs. You can cut down the editing time with timesaving Wizards, or get creative with easy hands-on tools. Put your video on DVD, tape or the Web, to share with family and friends.
- VideoStudio Editor gives you all the tools you need to produce great-looking home movies. Follow an easy, step-by-step workflow that lets you spend your time being creative rather than learning technical editing.
- Movie Wizard is ideal for users new to video editing. Select from attractive themes and let auto-editing create a professional opening sequence for you. Instantly produce entertaining photo slideshows with Smart Pan & Zoom. You'll have a complete movie in only three steps.
- Expandable Preview Screen features one of the largest preview windows of any video editor, so you can see how your finished movie will look.
- Multi-Trim Editor to extract multiple segments from videos for further editing.
- AccuCut Editing with Timeline Zoom lets you quickly find the exact frame to start trimming.
- Fix Common Video problems easily with Auto Color & Tone correction, DeBlock Filter, DeSnow Filter, and Anti-Shake filter to stabilizes video for better looking movies.
- Create 16:9 Widescreen and 4:3 standard menus for playback on any TV.
Ulead DVD MovieFactory 5 SE is an easy-to-use disc authoring and burning software that lets you do more with your digital media, e.g. creates DVDs with studio-quality personalized menus. Use the new Video Editing Wizard to polish up your videos, with titles, music and effects. Preserve your precious memories and share with family and friends.
- Trim your video to make it shorter, and rearrange clips as needed.
- Add video clips and photos to create mixed-media video and slideshows.
- Add titles to suit your production. Title size, position and style can be modified on-screen.
- Change background music if you like, adding your favorite music.
- Selectable for 16:9 or 4:3 PC monitors - make full use of all that extra screen space if you are using a widescreen monitor.
Package Contents
- VideoMate C100 Capture Card
- Driver CD
- Start Up Guide
- Ulead VideoStudio 11 SE CD
- Ulead DVD MovieFactory 5 SE CD
- 3.5mm phone jack patch cable
- 3.5mm phone jack to red/white RCA jack cable
