Best Value Adin B1BT 10W Vibration Speaker, Bluetooth - Blue
Quicklinx: 8QRQWS00 Mfr#: ADINB1BTBLUE
ADIN B1BT is the new generation of Vibration Speaker. Vibration speaker is a new concept of speakers which create sound through the vibration principle. By utilizing the new vibration resonance technology as the speaker transmits sound waves into the solid surface of metal, wood, glass, plastic, porcelain etc. The speaker transforms the surface to a gigantic 360-degree speaker. Connection is simple via Bluetooth. The little speaker weighs in at a third of a kilo, to set firmly on its surface.
Aluminium Alloy body
3.5mm Audio jack
Stream music via Bluetooth
Micro USB connection
Built-in Lithium battery, 3.7V, 800mAh
10W, DC 5.0V output power
Playtime: 2-3 hours / Charge time: 2-3 hours
Power supply: rechargeable Lithium Ion battery
USB cable, DC 5V adaptor
