Best Value 5MTR USB 2.0 A - B CABLE
Quicklinx: 5CF7WS00 Mfr#: USB2-105
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
FEATURES:
  • USB 2.0 and 1.1 compliant
  • High speed 480 Mbps data transfer speed
  • 4 downstream type A USB ports provided
  • Enables a PC to connect to high speed devices
  • Supports both OHCI and EHCI, data transfer speed up to 480 Mbps
  • Supports self power mode
  • Supports Plug and Play
  • Connect up to 127 USB devices
Cables Direct USB cable - 5 m
USB cable
Length
5 m
Connector(s)
1 x 4 PIN USB Type A - male
Connector(s) (Other Side)
1 x 4 PIN USB Type B - male
USB / Hi-Speed USB
USB cable
Length
5 m
Connector(s)
USB / Hi-Speed USB
