Best Value 45M USB EXTENDER OVER CAT 5E
Quicklinx: 5CFPWS00 Mfr#: USB-BOOSTA
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
You need a Local and Remote Unit (both supplied), and a CAT5/5E/6 Patch Lead up to 50 Mtrs in length (not supplied).
This product is compatible with USB devices that support USB 1.1 transfer speeds.
Typical Uses :
  • Connect USB web cams for security applications
  • Connect to USB barcode scanners
  • Extend USB devices past typical 5 metre range
Features:
  • Compliant with the USB 1.1 specification
  • Patented ASIC's (Application Specific Integrated Circuits) built in
  • Extends the distance of USB devices by up to 50 Mtrs using CAT 5/5E/6 Patch Cables
  • Embedded USB Transceivers in each unit to prevent signal loss
  • No external power needed
  • No drivers needed
  • Local Unit cable length: 30 CM
System Requirements:
  • IBM Compatible PC with 233 Mhz Pentium or faster
  • Windows 98SE / ME / 2000 or XP
  • Power Mac G3 or G4, PowerBook G3 or G4, or iBook
  • MAC OS 9.x or higher
  • 64 Mb Ram
  • Available USB Port
Length
30
