Best Value 2TB Verbatim 3.5" USB2 Hard Drive
Verbatim External Hard Drive USB 2.0 500GB
Quicklinx: 70M4WS00 Mfr#: 47514
Verbatim's External Hard Drive provides high capacity storage back up for all file types offering high performance and reliability to both the professional and home user.
Store thousands of digital photos, videos, music and other electronic files. It is powered by a SATA high-speed hard drive, the external hard drive races through the most demanding audio/video applications.
Its stylish 'steel' space saving design sits neatly on the modern desk top.
The Hi-Speed USB 2.0 interface makes the transfer of data quick and easy. Features include full synchronization and backup from your PC/laptop internal hard drive.
Key Features
  • Sleek `black steel' space saving design for the desk top
  • Hi-Speed USB 2.0 Interface
  • Drive type: SATA Hi-Speed
  • Cache: 8MB or higher
  • Nero BackITUP 4 Essentials Software
  • Back up software with optional back up settings to suit your requirements. Ad hoc or pre scheduled back up settings available.
  • Pack contents:
  • External Hard Drive
  • USB 2.0 cable
  • AC Power adaptor / cable
  • Quick Start Guide
  • Nero BackItUp 4 Essentials Software on the drive
  • User Guide included on the drive
Verbatim External Hard Drive - hard drive - 2 TB - USB 2.0
Hard drive - external (desktop)
2 TB
3.5"
USB 2.0
Data Transfer Rate
480 Mbps
Buffer Size
8 MB
Power Source
Included AC adapter
Enclosure Colour
Black steel
11.4 cm x 20.2 cm x 4 cm
1 kg
2 TB
3.5"
USB 2.0
Buffer Size
8 MB
11.4 cm
20.2 cm
4 cm
1 kg
Performance
Interface Transfer Rate
480 Mbps
Expansion & Connectivity
1 x USB 2.0
Compatible Bay
3.5"
Power Source
Included AC adapter
Power adapter
Software Included
NERO BackItUp 2 Essentials
Apple MacOS X 10.1 or later, Microsoft Windows Vista / 2000 / XP
1 x USB cable
Enclosure Colour
Black steel
