Best Value 21.6" Black LCD Monitor + Dvi
Quicklinx: 7033WS00 Mfr#: 2219A
Key Features
  • Panel size: 21.6"
  • Aspect Ratio: 16:9
  • Max Resolution: 1920 x 1080
  • DCR: 5000:1
  • Brightenss (Typ.): 300 cd/m²
  • Multimedia: Yes
  • DVI Input: Yes
  • Model Number : 2219A
  • Panel size : 21.6" 16:9
  • Pixel Pitch : 0.248 mm
  • Max Resolution : 1920 x 1080
  • Colour : 16.7M
  • DCR : 5000:1
  • Brightenss (Typ.) : 300 cd/m²
  • Response time (Tr + Tf) : 2ms
  • Viewing Angle
  • R/L/U/D : H:170 V:160
  • Lamp life : 40000 Hrs
  • Input Signal : DVI Analog RGB 0.7VP- p/ 75 ohm
  • Scan Frequency : H: 30-80KHZ V: 60-75HZ
  • OSD : Brightness, contrast , H./V. Position, Phrase Adjust, Colour Adjust, Language , Colour Recall, Exit
  • Languages: English, French, German, Italian, Spanish, Chinese
  • Audio (Speakers) : Yes
  • DVI : Yes
  • Power Adaptor Input : AC 100-240V , 50-60HZ Current: 1.2A
  • Power Consumption : 50W (Max)
  • Temperate : 0-40°C
  • Humidity : Less than 80%
  • Altitude : To 10,000 feet
  • Power Management : VESA DPMS
  • Plug & Play : DDC 2B
  • Colour Button on back Frame : Menu, Down, Up, Auto, Power
  • Accessory package : Monitor, Base, AC Power Cord, Audio Cable, User Manual, Warranty Card
  • Saftey & EMI : CE, RoHS
  • Dimensions Without Base: 509.6 x 62.74 x 328.20 (mm)
  • Dmensions With Base: 509.6 x 200.5 x 388.20 (mm)
