The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
Highlights of the Best Value L-1962WD 19" monitor
- Screen: 19" WXGA+ widescreen 1366 x 768(WXGA)
- Brightness: 300 cd/m2
- Contrast Ratio: 500:1
- Response time: 5ms
- Connectivity: DVI and D-Sub
- Max Resolution 1366 x 768(WXGA)
- Pixel Pitch 0.285 x 0.285mm
- Display Colors 16.2M
- Scan Frequency H:30-80KHz V:56-75Hz
- Integrated Multimedia speakers
- 3 years warranty
- Dimensions & Weight / Depth
- 16
- Black
- Diagonal Size
- 19
- Manufacturer
- Digimate
- Dimensions & Weight / Height
- 37
- Packaged Quantity
- 1
- Display (Projector) / Dot Pitch / Pixel Pitch
- 0.285
- Dimensions & Weight / Width
- 44
- Speakers
- Speaker(s)
- Television / Viewing Angle
- 150 degrees
- D-sub
- DVI
- 4.9
- Max Resolution
- 1366x768
- Product Line
- Digimate
- Response Time
- 5
- Service & Support Details / Full Contract Period
- 3 years
- Service & Support / Type
- 3 years warranty
- Model
- L-1935WD
- Display (Projector) / Image Brightness
- 300
- Television / Viewing Angle (Vertical)
- 130 degrees
- Technology
- TFT active matrix
- Display (Projector) / Image Contrast Ratio
- 500:1
- Service & Support Details / Type
- Limited warranty
