XL-series features the premiere monitors for PC e-Sports, fine-tuned to guarantee the smoothest and responsive experience, and the clearest images to arm you for competition.
DyAc technology - same 144 Hz, different clarity
BenQ ZOWIE exclusive technology - "Dynamic Accuracy" maintains remarkable clarity during in-game movement that achieves a smoother experience, enabling players to swiftly capture and hit the targets. -
Shield - helps you focus on the game
Shield - reveal the way to be concentrated in games. The adjustable angle and removable design allows Shield to adopt various environments according to preference. Just focus on winning the game. -
Easily access settings for different scenarios
Different usage scenarios require different display settings. The S Switch is designed for easy access to settings and switching between saved modes. Whether you are watching, reading, surfing or gaming, switching between the presets and navigating among menus is as simple as 1-2-3. The built-in memory is for saving preferred 3 profiles to go with driverless design.
- BenQ ZOWIE XL2735 - XL Series - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 65 kWh
- Power Consumption (On mode)
- 45 W
- USB Hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 144 Hz
- Pixel Pitch
- 0.2335 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Input Connectors
- 2xHDMI, DVI-D, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 63.3 cm x 22.6 cm x 55.9 cm
- 8.3 kg
- Display Type
- Energy Class
- Class C
- 65 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB Hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2335 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Backlight Technology
- LED backlight
- Black eQualizer, Low Blue Light Mode, Flicker Free technology, e-Sports, Shield
- 63.3 cm x 22.6 cm x 55.9 cm - with stand
- 8.3 kg
- 2 x HDMI , DisplayPort , DVI-D (dual link) , Headphones , Microphone , USB upstream , 3 x USB downstream
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 140 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Protective cover, S Switch remote control
- MTBF
- 60,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- 45 W
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 63.3 cm - depth: 6.4 cm - height: 37.4 cm , With stand - width: 63.3 cm - depth: 22.6 cm - height: 55.9 cm - weight: 8.3 kg
