BenQ XL2730 Zowie 27" 2560x1440 2ms USB DP HDMI DVI-D LED Gaming
Quicklinx: CNRJWS00 Mfr#: 9H.LEVLB.QBE
BenQ Zowie's XL-series features the premiere e-Sports monitors for PC competitors, fine-tuned to guarantee the smoothest and responsive experience, and the clearest images to arm you for competition.
  • Enhanced visuals
    Experience high visual quality with a 27-inch display boasting a native resolution of 2560 x 1440, complemented by LED backlight technology for vivid colors and deep blacks. The dynamic contrast ratio of 120,000,000:1 ensures detailed images in both light and dark scenes.
  • Ergonomic design
    Designed with comfort in mind, the monitor offers extensive display position adjustments including height, pivot, swivel, and tilt, allowing users to find the perfect viewing angle for long gaming sessions or work hours.
  • Optimized for gaming
    With a fast response time of 1 ms and a V-Sync Rate at Max Res. of 144 Hz, gamers can enjoy smooth, uninterrupted gameplay. Features like Black eQualizer, Flicker-Free technology, and Motion Blur Reduction enhance the gaming experience by improving visibility and reducing eye strain.
  • Versatile connectivity
    Equipped with multiple input options including 2xHDMI, DVI-D, VGA, and DisplayPort, this monitor offers flexibility for connecting to a wide range of devices. The built-in USB hub further enhances connectivity, allowing for easy attachment of peripherals.
  • Eye care technology
    Protect your eyes during long usage periods with Flicker-Free technology and Low Blue Light Mode, reducing the risk of eye strain and fatigue.
BenQ ZOWIE XL2730 - XL Series - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
60 kWh
Power Consumption (On mode)
41 W
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 144 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 90 - 264 V
Grey, red
63.3 cm x 22.6 cm x 55.7 cm
7.5 kg
Environmental Standards
ENERGY STAR Qualified
TUV Bauart
Display Type
Energy Class
Class B
60 kWh
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, game mode, Black eQualizer, Low Blue Light Mode, Flicker Free technology, Motion Blur Reduction, K Locker, e-Sports
Grey, red
63.3 cm x 22.6 cm x 55.7 cm - with stand
7.5 kg
2 x HDMI (HDCP) , VGA (HD-15) , DisplayPort , DVI-D (dual link) , Headphones , Microphone , USB upstream , 3 x USB downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
VESA Mounting Interface
100 x 100 mm
S Switch remote control
TUV Bauart
Security Slot Type
Kensington security slot
Input Voltage
AC 90 - 264 V
41 W
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - depth: 6.1 cm - height: 33.5 cm , With stand - width: 63.3 cm - depth: 22.6 cm - height: 55.7 cm - weight: 7.5 kg
Sustainability Information
ENERGY STAR Certified
5 °C
20 - 90%
