The XL2420T demonstrates BenQ's true belief that "gaming is in the details" It has been co-developed with Counter-Strike pro gaming legends to bring you a gaming monitor like no other - from the attentive designs to the exceptional functions. With the precision and speed you would expect from a high-performance gaming monitor, you can now have a vantage point over your opponents in all your game play.
The task of conceptualizing the XL2420T as the ultimate gaming monitor involved a unique collaboration with prominent pro gamers: Tommy "Potti" Ingemarsson, Emil "HeatoN" Christensen, Abdisamad "SpawN" Mohamed, Michael "ahl" Korduner and Christer "fisker" Eriksson. These five names alone are synonymous when it comes to legendary Counter-Strike players. Their accumulated wealth of knowledge and skills helped BenQ develop a monitor that adapts to the needs of gamers to improve their chances of winning.
Poor visibility in dark scenes can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
The XL2420T comes with a stylish S Switch. This distinct remote controller comes with three preset buttons so you're able to customize and save your display settings for gaming, work or entertainment purposes. Use the scroll button on the S Switch to quickly navigate and change the OSD settings. It eliminates the tedious process of adjusting your monitor settings.
The display mode and smart scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Or take advantage of the smart scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
Special collaboration with renowned counter-strike legends
The task of conceptualizing the XL2420T as the ultimate gaming monitor involved a unique collaboration with prominent pro gamers: Tommy "Potti" Ingemarsson, Emil "HeatoN" Christensen, Abdisamad "SpawN" Mohamed, Michael "ahl" Korduner and Christer "fisker" Eriksson. These five names alone are synonymous when it comes to legendary Counter-Strike players. Their accumulated wealth of knowledge and skills helped BenQ develop a monitor that adapts to the needs of gamers to improve their chances of winning. -
The Black eQualizer gives you total visibility
Poor visibility in dark scenes can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation. -
Specially designed s switch for swift control and navigation
The XL2420T comes with a stylish S Switch. This distinct remote controller comes with three preset buttons so you're able to customize and save your display settings for gaming, work or entertainment purposes. Use the scroll button on the S Switch to quickly navigate and change the OSD settings. It eliminates the tedious process of adjusting your monitor settings. -
Customize your individual viewing preference
The display mode and smart scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Or take advantage of the smart scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game. -
Play like a pro with the exclusive FPS mode
The preset FPS mode tailored by HeatoN and SpawN gives you the optimal brightness, contrast, sharpness and color tint in FPS games so you can spot your opponents and track their every move, even in indistinct situations. There are two variations to this special mode this year: the FPS1 mode is designed for Counter-Strike 1.6 and the FPS2 mode for Counter-Strike Source. The perfect combination of form and function provides gamers with the vantage point to always be one step ahead of the game. -
120 Hz refresh rate ensures seamless graphics
With a refresh rate of 120Hz, there's never a lag and every in-game details will be smoothly rendered. Drawing on hyper-speed video processing technology, the XL2420T gives you on-screen action and captivating realism. -
Fast 2 ms GTG response time
Fast response time of 2 ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display. -
Intuitive UI for easy navigation
The designed OSD enables you to conveniently change your settings in an intuitive horizontal slide out menu display. -
The game mode loader lets you in on the secret
The secret is out. Download special gaming presets used by HeatoN and SpawN so you can see what the pros see. Each mode is fine tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. Users can install these exclusive presets and leverage them to their advantage. More presets from legendary gamers will be released in the future so you can always stay on top of your game. -
Ultra-flexible height adjustment stand and others
The Height Adjustment Stand can be operated with just one finger so you can effortlessly adjust the height of the monitor to suit your sight level. Have the monitor way up high, or change it to sit flat on the table. The monitor can also be turned vertically or horizontally and comes with a quick-release VESA mount design. In addition, the sleek headphones hook at the back keeps your desk top neat and tidy. -
NVIDIA 3D Vision 2 with complete connectivity
Certified as NVIDIA 3D Vision 2-ready with the new NVIDIA 3D LightBoost technology so you can experience gaming and entertainment like never before with total realism and intensive graphic display. Furthermore, the XL2420T supports D-Sub, HDMI, DVI-DL and DP inputs for console gaming action. -
ecoFACTS label
ecoFACTS can tell you how eco-friendly BenQ products are! Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products! ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products. -
ENERGY STAR qualified
The XL2420T complies with the requirements for ENERGY STAR program for computer monitors V5.1. Enjoy saving energy and money while keeping the Earth looking great.
- BenQ XL2420T - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.276 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray), 5 ms (typical)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, DVI-D, VGA
- Height, swivel, tilt
- Black / red
- 57.1 cm x 15 cm x 51.7 cm
- 6.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Diagonal Size
- 24"
- 3D Technology
- Alternate-frame sequencing
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 120 Hz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- HDCP, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Black eQualizer, Smart Scaling
- Black / red
- 6.1 kg
- VGA , DVI-D , HDMI , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- Cables Included
- 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
