The BenQ V70 series with the narrow bezel chic design, delivers rich and exquisite visual performance that please your eyes. A pure expression of broad viewing from inside out.
Minimal slim bezel design for ultimate sophistication
Visually stunning inside and out, BenQ VZ2770H is designed to enhance your viewing experience like never before. Feast your eyes on the impeccable view from the edge-to-edge (E2E) ultra-thin bezel design and supreme image performance. -
Industry-leading eye-care technology
BenQ exclusive eye-care technologies reduce eye fatigue for user comfort, enhanced productivity, and workplace safety during extended use. -
Low Blue Light technology
Unique BenQ Low Blue Light technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation. -
Flicker-free
Flicker-free eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 250 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ flicker-free monitor. -
3000:1 ultra-high native contrast for depth and definition
Ultra-high 3000:1 native contrast, 3X higher than standard panels, adds astonishing color depth and definition to complex dark images with exquisite subtlety and clarity. High native contrast also enables infinite dynamic contrast to far exceed the highest expectations. -
178°/178° Wide Viewing Angles
Advanced VA (Vertical Alignment) panel technology delivers truly authentic colors and ultra-sharp details from left, right, above and below with 178°/178° viewing angles for an unsurpassed viewing experience. -
Fast 4 ms GTG response time
Super-fast 4 ms GTG response eliminates motion smear for smooth video and gaming. Fast-moving action and dramatic transitions render flawlessly without lag or ghosting. Enjoy immersive gaming and video entertainment without delay. -
8-bit color display
With the ability to render 16.7 million color shades simultaneously, you can expect true colors, silky transitions and impeccable image quality. -
HDMI multimedia interface
The HDMI high-speed multimedia interface enables effortless convenience to enjoy digital entertainment from today's source devices as well as tomorrow's multimedia equipment.
- BenQ VZ2770H - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 51 kWh
- Power Consumption (On mode)
- 35 W
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 90 - 264 V
- 61.4 cm x 21.184 cm x 46.116 cm
- 5.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class B
- 51 kWh
- Diagonal Size
- 27"
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 6500K, 5700K
- Slim Design, Low Blue Light Mode, Flicker Free technology, ecoFACTS Label, 72% NTSC colour gamut
- 5.3 kg
- VGA , 2 x HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Cables Included
- 1 x VGA cable - 1.5 m , 1 x HDMI cable - 1.5 m
- Backlight Life
- 30,000 hours
- MTBF
- 60,000 hour(s)
- Input Voltage
- AC 90 - 264 V
- 35 W
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- OS Required
- Microsoft Windows 7 / 8 / 8.1
Sustainability Information
- ENERGY STAR Certified
