BenQ VZ2770H 27" 1920 x 1080 4ms HDMI VGA LED Monitor
Quicklinx: CF8PWS00 Mfr#: 9H.LEDLB.Q5E
The BenQ V70 series with the narrow bezel chic design, delivers rich and exquisite visual performance that please your eyes. A pure expression of broad viewing from inside out.
  • Minimal slim bezel design for ultimate sophistication
    Visually stunning inside and out, BenQ VZ2770H is designed to enhance your viewing experience like never before. Feast your eyes on the impeccable view from the edge-to-edge (E2E) ultra-thin bezel design and supreme image performance.
  • Industry-leading eye-care technology
    BenQ exclusive eye-care technologies reduce eye fatigue for user comfort, enhanced productivity, and workplace safety during extended use.
  • Low Blue Light technology
    Unique BenQ Low Blue Light technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation.
  • Flicker-free
    Flicker-free eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 250 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ flicker-free monitor.
  • 3000:1 ultra-high native contrast for depth and definition
    Ultra-high 3000:1 native contrast, 3X higher than standard panels, adds astonishing color depth and definition to complex dark images with exquisite subtlety and clarity. High native contrast also enables infinite dynamic contrast to far exceed the highest expectations.
  • 178°/178° Wide Viewing Angles
    Advanced VA (Vertical Alignment) panel technology delivers truly authentic colors and ultra-sharp details from left, right, above and below with 178°/178° viewing angles for an unsurpassed viewing experience.
  • Fast 4 ms GTG response time
    Super-fast 4 ms GTG response eliminates motion smear for smooth video and gaming. Fast-moving action and dramatic transitions render flawlessly without lag or ghosting. Enjoy immersive gaming and video entertainment without delay.
  • 8-bit color display
    With the ability to render 16.7 million color shades simultaneously, you can expect true colors, silky transitions and impeccable image quality.
  • HDMI multimedia interface
    The HDMI high-speed multimedia interface enables effortless convenience to enjoy digital entertainment from today's source devices as well as tomorrow's multimedia equipment.
BenQ VZ2770H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
51 kWh
Power Consumption (On mode)
35 W
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
61.4 cm x 21.184 cm x 46.116 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
51 kWh
35 W
Diagonal Size
27"
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 5700K
72% NTSC colour gamut, Slim Design, Low Blue Light Mode, Flicker Free technology, ecoFACTS Label
5.3 kg
VGA , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
1 x VGA cable - 1.5 m , 1 x HDMI cable - 1.5 m
Backlight Life
30,000 hours
MTBF
60,000 hour(s)
AC 90 - 264 V
27 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Microsoft Windows 7 / 8 / 8.1
ENERGY STAR Certified
CF8P C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £10.18
CF8P C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £11.43
CF8P C2G VGA to Composite PC-TV Video Adapter In Stock £33.18
