BenQ ST650K 65" 3840x2160 8ms VGA HDMI LED Large Format Display
Quicklinx: CWMLWS00 Mfr#: 9H.F38TK.RA2
TV Tuner Presence: No
Video Interface: Component, Composite, HDMI
£1,132.93 ex VAT
£1,359.51 inc VAT
The 65-inch ST650K is the total package suitable for small business and corporate setting. It brings together a wide variety of features, including stunning 4K resolution for enhanced engagement, stylish slim design, X-Sign software for effortless content creation and management, and MDA application for hassle-free display control. On top of this, with the easy-to-use meeting solution zoom, you can instantly connect your teams and clients without expensive infrastructure. It is the solution saving you time, efforts and resources all at once.
BenQ ST650K 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Motion Enhancement Technology
60 Hz Frame Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15), Mobile High-Definition Link (MHL)
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Digital signage
Speaker System
2 speakers
USB
4 ports
Remote Control
Standard remote
Voltage
AC 120/230 V
Energy Class
Class B
200 Watt
Power Consumption (On mode)
167 W
Energy Consumption per Year
244 kWh
146.2 cm x 8.8 cm x 84.4 cm
20 kg
Energy Class
Class B
200 Watt
167 W
244 kWh
Diagonal Class
65"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
3 ports
PC Interface
Modes
Landscape mode
Dimensions
Without stand
146.2 cm
8.8 cm
84.4 cm
20 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Frame Rate
Image Contrast Ratio
1200:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Backlight Life
30,000 hours
Commercial Features
Digital signage
Stands & Mounts
Stand
Optional
Media Player
USB Port
USB Ports Qty
4
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x speaker - built-in - 8 Watt
Network & Internet Multimedia
LAN
Connector Type
2 x HDMI , MHL/HDMI input , Audio line-in , Composite video input , Component video input , VGA input , 4 x USB , Network , Audio line-out , Composite video output
VGA cable , HDMI cable
Power supply
Nominal Voltage
AC 120/230 V
On / Off Switch
Weight (Shipping)
28 kg
Video Interface: Composite
Video Interface: HDMI
Brand: BenQ
Price Range Ex VAT: 1000 - 1500
