Featuring the eye-care technology, BenQ IFP RP840G can reduce harmful effects from blue light emissions. With its Interactive Flat Panel, the driver-free touch-screen functionality is right out of the box on major operating systems and most supported platforms. BenQ IFP RP840G is the innovative display system that fits every classroom's need.
Low blue light technology
The interactive flat panels are built with BenQ's low blue light technology to reduce harmful blue spectrum light emission, which causes eyestrain, eye fatigue and even mascular degeneration. The low blue light technology features the Classroom mode that combats the possible side effects associated with blue light in every usage occasion. -
Anti-glare glass
The screen's anti-glare glass reduces reflection, for more legible text and clearer images, helping students avoid eyestrain and facilitating more effective instruction. -
OSD menu with Touch
OSD menu with Touch is straight forward to use and allows users to switch video source/volume/brightness at fingertips. This provides you a more intuitive way to use IFP even without the help of the remote controller/button. -
Multi-platform compatibility
Compatible with major operating systems from Windows to Mac, Linux and Chrome, the interactive flat panels are built to work seamlessly with a wide range of computing and mobile devices with a simple plug and play. -
DisplayNote software
The DisplayNote software is a cross platform solution that facilitates real-time collaboration across multiple computing and smart devices, enabling everyone to stream content and contribute to the presentation. The Wireless Desktop Control feature further allows teachers to mirror and wirelessly control their PC from anywhere in class, freeing them from traditional lecture style teaching. -
BenQ QCast
The BenQ QCast software enables seamless wireless streaming and mirroring of all digital contents through a BenQ WiFi dongle, empowering teachers to enrich their lesson plans with a variety of multimedia resources. -
Build-in EZWrite software
The EZWrite Software supports annotation function easily. With this build-in whiteboard software or function, educators are able to write and paint directly without any device, like PC/NB. -
MDA software (LAN only)
Multiple Display Administrator (MDA) saves time and effort by providing remote management of BenQ Interactive Flat Panel MDA also supports remote shutdowns of equipment not in use, saving significant power costs. -
Ultra-high-definition resolution
A 3840x2160 4K2K ultra-high-definition (UHD) resolution offers over 300% more working space than a 1920x1080 FHD does - for the most detailed on-screen viewing quality.
- BenQ RP840G 84" LED-backlit LCD display - 4K
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 84"
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Picture Enhancements
- 72% Colour Saturation NTSC
- Speaker System
- 2 speakers
- USB
- 2 ports
- Included Accessories
- Remote control, 2 touch pens, DisplayNote card
- Voltage
- AC 120/230 V (50/60 Hz)
- 550 Watt
- Power Consumption Stand by
- 0.5 Watt
- 197.82 cm x 9.5 cm x 118.6 cm
- 116 kg
- 3-year warranty
- Product Type
- 550 Watt
- Diagonal Class
- 84"
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- VGA (HD-15)
- Modes
- Landscape mode
- Protection
- Tempered glass protection
- 197.82 cm
- 9.5 cm
- 118.6 cm
- 116 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- LED backlight
- Coating
- Anti-glare
- Image Contrast Ratio
- 1600:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 10
- Response Time
- 8 ms
- Display Menu Language
- English, French, Spanish
- Backlight Life
- 50,000 hour(s)
- Eye Care, infrared multitouch technology, Low Blue Light Technology, EZWrite Software, Multiple Display Administrator (MDA)
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 600 x 600 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- Composite video input , 4 x HDMI input , 3 x VGA input , VGA output , Serial input , LAN , 2 x USB , Audio input , Headphones , 3 x audio line-in , Audio output
- 2 touch pens, DisplayNote card
- Cables Included
- USB cable - 10 m , VGA cable - 5 m , Audio cable - 5 m
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - 3 years
- Width (Shipping)
- 217 cm
- Depth (Shipping)
- 32 cm
- Height (Shipping)
- 137 cm
- Weight (Shipping)
- 146 kg
