BenQ RP703 70" Interactive Touch Screen Display
Quicklinx: CBK2WS00 Mfr#: 9H.F2VTC.DE2
  • 1080p
The BenQ is committed to empowering educators with the ultimate interactive classroom display technology. Hardware and software play equally important roles in promoting effective learning. This statement has driven the development of the RP703 HD interactive blackboard display. This advanced panel is designed to support teachers by bringing to the classroom a truly interactive solution that engages students and promotes collaborative learning.
  • Subjects easier to explain
    The BenQ RP703 touch interactive flat panel provides educators with the access to tools and resources never before available. With improved access to interactive online resources, teachers can explain and illustrate subjects in ways students can more easily understand. This increases students' interest in the subjects at hand and improves the classroom experience.
  • Readability matters
    BenQ RP703 interactive flat panel is designed to help educators make a natural transition from traditional lecture-style teaching to truly collaborative learning. The HD classroom ready display is large enough to replace existing blackboards, whiteboards and interactive whiteboards while providing crisp, bright text that is easy to read from anywhere in the classroom.
BenQ RP703 70" LED-backlit LCD display - Full HD - for digital signage / interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
70"
Commercial Use
Yes - interactive digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite, HDMI
HDMI Ports Qty
4 ports
LAN
PC Interface
VGA (HD-15)
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
4 ports
Remote control, 2 touch pens
Voltage
Energy Class
Class B
Power Consumption (On mode)
188 W
Energy Consumption per Year
274 kWh
166.5 cm x 9.8 cm x 101.5 cm
3-year warranty
Energy Class
Class B
188 W
274 kWh
Diagonal Class
70"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
NFC sensor
Video Interface
Composite, HDMI
HDMI Ports Qty
4 ports
PC Interface
VGA (HD-15)
166.5 cm
9.8 cm
101.5 cm
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Coating
Anti-glare
Image Contrast Ratio
1400:1
Brightness
360 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
20
Response Time
6 ms
Backlight Life
30,000 hour(s)
Infrared multitouch technology, Low Blue Light Technology, EZWrite Software, Flicker free technology
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
4
Operating System
Android OS 4.2.1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connect & Share
Mobile High-Definition Link (MHL)
Connector Type
3 x VGA input , LAN , 4 x HDMI input , Composite video/audio input , 3 x audio line-in , Serial , USB 3.0 , USB , 3 x USB 2.0 , Headphones
2 touch pens
Power supply
Input Voltage
On / Off Switch
Limited warranty - 3 years - on-site
