BenQ RP552H 55" Touch Screen Display
Quicklinx: CBT5WS00 Mfr#: 9H.F2FTC.DE2
  • 1080p
With a 55-inch Full HD screen, powered by proficient EZWrite 3.0 annotation tools and touch driver-free design, the RP552H is the perfect interactive display for teaching in a small-sized classroom. The RP552H is ready to use straight out of the box and requires nearly no warm-up time, making it a great hassle-free way to bring touch-enhanced learning to your classroom.
  • Multi-touch interactivity
    Multi-touch support makes the RP552H perfect for group activities and classroom games that motivate collaboration and communication.
  • Data-to-go
    Save annotations as images and share them as review material through a variety of methods, including QR code, USB, or display's internal memory.
BenQ RP552H Education Series - 55" LED-backlit LCD display - Full HD
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
55"
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
4 ports
Remote control, 2 touch pens
Voltage
Energy Class
Class B
162 Watt
Power Consumption (On mode)
123 W
Energy Consumption per Year
179 kWh
130.4 cm x 9.7 cm x 80 cm
33 kg
Energy Class
Class B
162 Watt
123 W
179 kWh
Diagonal Class
55"
Combined With
Touchscreen
Series
Education Series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
Modes
Landscape mode
Protection
Tempered glass protection
130.4 cm
9.7 cm
80 cm
33 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Coating
Anti-glare
Image Contrast Ratio
1200:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
10
Response Time
6 ms
Display Menu Language
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese
Backlight Life
50,000 hour(s)
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
4
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
Composite video input , USB 3.0 , 3 x USB 2.0 , Digital audio output (coaxial) , Headphones , 3 x audio line-in , VGA output , Audio line-in , 3 x HDMI input , 3 x VGA input , Serial input , LAN
2 touch pens
VGA cable - 3 m , USB cable - 5 m , Audio cable
Power supply
Input Voltage
On / Off Switch
Width (Shipping)
145.8 cm
Depth (Shipping)
22 cm
Height (Shipping)
93.2 cm
Weight (Shipping)
42 kg
