The RL2455HM is a professional gaming monitor suited for RTS game play. This 24" W LED monitor is packed with the features: the black eQualizer, height adjustment Stand, RTS mode, display mode, smart scaling, 1 ms GTG, HDMI and 12M: 1 dynamic contrast ratio. Poor visibility in dark scenes can cost even the most skillful gamers their game. The black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
Exclusive RTS mode ensures you would play like a pro
Every feature and function of the RL2455HM was meticulously through out to provide RTS gamers with vital visibility and command to achieve peak performance. This out-of- the-box preset automatically fine-tunes your monitor accordingly for optimum RTS gaming, allowing you to see your enemies more visibly among the distractions and darkened areas. Built to give you the competitive edge, the exclusive RTS Mode will be your ultimate secret weapon. The exclusive preset RTS Mode will be your ultimate secret weapon. -
Customize your individual viewing preference
The display mode and smart scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Or take advantage of the smart scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game. -
Fast 1 ms GTG response time
Fast response time of 1 ms GTG means speed without the smear. Fast-moving action and dramatic transitions will be rendered smoothly - without smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display. -
ENERGY STAR qualified
The RL2455HM complies with the requirement of ENERGY STAR program for computer monitors. Now you can enjoy saving energy and money as well as keeping the Earth looking great!
- BenQ RL2455HM - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 39 kWh
- Power Consumption (On mode)
- 27 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey), 5 ms (typical)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Swivel, tilt
- Voltage
- AC 120/230 V
- Black / red
- 57.9 cm x 18.9 cm x 43.5 cm
- 4.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class B
- 39 kWh
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- HDCP, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Black eQualizer, Smart Scaling
- Black / red
- 57.9 cm x 18.9 cm x 43.5 cm - with stand
- 4.1 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- DVI-D (dual link) , 2 x HDMI , VGA , Headphones , Audio line-in
Mechanical
- Swivel, tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 27 W
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- No
- OS Required
- Microsoft Windows 7, Windows 8
- Dimensions & Weight Details
- Without stand - width: 57.9 cm - depth: 6.3 cm - height: 35 cm , With stand - width: 57.9 cm - depth: 18.9 cm - height: 43.5 cm - weight: 4.1 kg
Sustainability Information
- ENERGY STAR Certified
