Extended lamp life
Enjoy an extension in your projector's operational life with a lamp life cycle of up to 2500 hours, extending to 3000 hours in Economic Mode. This feature ensures your presentations and media can shine for longer without the need for frequent lamp replacements, making it a cost-effective solution for both personal and professional use. -
Seamless compatibility
Designed specifically for PC compatibility, this projector lamp integrates smoothly with your existing setup. Its precise engineering ensures optimal performance and reliability, allowing you to focus on delivering impactful presentations without worrying about hardware mismatches.
- BenQ projector lamp
- Product Type
- Projector lamp
- Bulb life cycle
- 2500 hour(s) (standard mode) / 3000 hour(s) (economic mode)
- Designed For
- BenQ MW767, MX766, MX822ST
- Product Type
- Projector lamp
Lamp
- Life Cycle
- Designed For
