Extended lamp life
With a standard lamp life cycle of 4500 hours and an extended 10000 hours in Economic Mode, this projector lamp ensures long-lasting performance, reducing the need for frequent replacements and maintenance. -
High compatibility
Designed specifically for PC compatibility, this projector lamp seamlessly integrates with your existing setup, offering a hassle-free upgrade or replacement solution.
- BenQ projector lamp
- Product Type
- Projector lamp - 190 Watt
- Bulb life cycle
- 4500 hour(s) (standard mode) / 10000 hour(s) (economic mode)
- Designed For
- BenQ MS504, MX505
- Product Type
- Projector lamp
Lamp
- Capacity
- 190 Watt
- Life Cycle
- Designed For
- BenQ MS504, MX505
