BenQ MX819ST DLP XGA 3000 Lumens Projector
Quicklinx: 9G8BWS00 Mfr#: 9H.J7477.15E
A wide array of connectivity options plus PointWrite and QWrite interactive features make the MX819ST a complete classroom projector solution. An 0.61 short-throw ratio, 13000:1 sharp contrast ratio, 3000 ANSI lumen brightness and long lamp life ensure vibrant, reliable visual performance time and again.
  • World-leading SmartEco technology for a greener environment
    As the first DLP brand to incorporate Philips' ImageCare technology into its projector lamp system, BenQ has taken a further leap, developing its own SmartEco technology to perfect what DLP can do for energy saving in the 21st century classroom. The MX819ST brings together uncompromised brightness, exquisite picture quality and optimized lamp life through innovative features.
  • Eco blank mode
    The eco blank mode allows teachers to blank the projection screen whenever they need to direct their students' focus back on them - or simply when the projector is not in use. When activated, this special feature dims the lamp power automatically, lowering the total power consumption by 70%.
  • No source detected mode
    The automatic switch to eco blank mode after the projector is turned on for over three minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp.
  • Ultra-high contrast ratio
    An ultra-high contrast ratio projects sharp images, even for high brightness projectors. Get better contrast and blacker blacks with a 13000:1 contrast ratio.
  • 0.5 W in standby mode
    When inactive, the MX819ST complies with 2013 EU standards by keeping power consumption to a minimum using less than 0.5 W on standby, extending lamp life and reducing energy costs.
  • Blu-ray Full HD 3D supported
    BenQ MX819ST is built with latest DLP technology to support 3D functionality, allowing schools to bring an immersive learning experience to their students with a simple preparation of 3D glasses and 3D content from your Blu-ray player.
  • Zero eye-blinding lights
    The short-throw projection distance keeps the projector light from shining directl into your eyes, allowing you to keep your focus on your audience.
  • Zero disruptions
    Say goodbye to the shadows that often interrupt your presentation. With a projection distance this close, you and your audience can move freely without worrying about obstructions between the projector and the screen!
  • LAN control with Crestron and PJ-Link
    LAN control is designed to help IT managers perform day-to-day projector maintenance and repair tasks efficiently and effectively - offering them full access and control over every projector directly from their workstations. The MX819ST offers seamless support for the Crestron and PJ-Link LAN control system.
BenQ MX819ST - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3000 ANSI lumens
Contrast Ratio
13000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
270 watt
28.73 cm x 23.26 cm x 11.44 cm
2.6 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3000 ANSI lumens
Contrast Ratio
13000:1
Image Size
152 cm - 762 cm
Throw Ratio
0.61:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
190 watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
Closed Caption, PJlink, ecoFACTS, SmartEco Technology, Eco Blank
Lens
Lens Aperture
F/2.6
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
Lens cover, wireless remote control
1 x VGA cable
Security Features
Security Slot Type
Kensington security slot
270 watt
Power Consumption Stand by
0.5 watt
28.73 cm
23.26 cm
11.44 cm
2.6 kg
Sound Emission
32 dBA
28 dBA
