Featuring a brightness of 3200 ANSI lumens and a high contrast ratio of 13000:1, the cost-effective and eco-friendly MX507 offers a stunning full-screen presentation with the finest details regardless of the ambient light level.
Saving more on power consumption with BenQ's SmartEco technology
Offering lower TCO and optimized projection through dynamic power saving, uncompromised brightness, exquisite picture quality and optimized lamp life - SmartEcoTechnology has perfected what a DLP projector can do. With this innovation, schools and corporations are able to save up to 70% of lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid viewing experience into every presentation. -
Smart Eco mode
The smart Eco mode, which cleverly adjusts the lamp power to maximize power saving by delivering the best contrast and brightness performance using only as much light as needed. -
LampSave mode
Projector lamp replacement costs make up the biggest part of the total cost of projector ownership. The LampSave mode is designed to adjust the lamp power dynamically by content brightness level to extend projector lamp life significantly by 50%! The lamp replacement frequency is also reduced by up to 50% to lower the replacement costs. -
Eco blank mode
The Eco blank mode allows teachers to blank the projection screen whenever they need to direct their students' focus back on them - or simply when the projector is not in use. When activated, this special feature dims the lamp power automatically, lowering the total power consumption by 70%. -
No source detected mode
The automatic switch to Eco blank mode after the projector is turned on for over three minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp. -
0.5 W in standby mode
When inactive, the MX507 keeps power consumption to a minimum with 0.5 W standby power, achieving what was once a challenge for earlier projector models. This technological advancement in energy saving certainly helps extend the projector lamp life and lower energy costs. -
Audio pass through
With the built-in speaker, the MX507 can be used as an audio system when it's on the standby mode. This saves you the trouble as well as the extra budget for getting a separate audio system. -
Timeless image quality
BenQ DLP projectors are built with enduring enjoyment in mind, ensuring razor-sharp clarity, ultra-readability and true-to-life color for years to come. Since the mirrors are colorless and protected within a nearly-sealed engine, BenQ DLP projectors have no aging problems and are virtually immune to image decay, consistently delivering picture excellence time and time again. -
Razor-sharp clarity with ultra-readability
Enabling a 96% fill factor, DLP technology supplies pixel circuitry behind the pixel, thereby eliminating the thick dark bezels around individual pixels, which diminish color and detail. A higher fill factor and less black border translate to noticeably purer, more intense color and smoother image quality.
- BenQ MX507 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 13000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 270 watt
- 28.3 cm x 22.2 cm x 9.5 cm
- 1.8 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 13000:1
- Image Size
- 152 cm - 762 cm
- Throw Ratio
- 1.96 - 2.15:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 190 watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- ecoFACTS, SmartEco Technology
Lens
- Lens Aperture
- F/2.56-2.68
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, component video, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 watt
- Speakers
- 1 x mixed channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- 270 watt
- Power Consumption Stand by
- 0.5 watt
- 28.3 cm
- 22.2 cm
- 9.5 cm
- 1.8 kg
- Sound Emission
- 33 dB
- Sound Emission (Economic Mode)
- 28 dB
