The BenQ MS619ST offers the highest display flexibility - giving you a 55" big picture in a mere projection distance of 1 meter! Featuring 3000 ANSI lumen high brightness and 13000:1 high contrast ratio and DLP Link 3D technology, this SVGA projector is the perfect match for small-sized business and education settings!
World-Leading SmartEco technology for a greener environment
As the first DLP brand to incorporate Philips' ImageCare technology into its projector lamp system, BenQ has taken a further leap, developing its own SmartEco technology to perfect what DLP can do for energy saving in the 21st century classroom. Built with this invention, the MS619ST brings together uncompromised brightness, exquisite picture quality and optimized lamp life through innovative features. -
SmartEco mode
The SmartEco mode, which cleverly adjusts the lamp power to maximize power saving by delivering the best contrast and brightness performance using only as much light as needed. -
LampSave mode
Projector lamp replacement costs make up the biggest part of the total cost of projector ownership. The LampSave mode is designed to adjust the lamp power dynamically by content brightness level to extend projector lamp life significantly by 50%! The lamp replacement frequency is also reduced by up to 50% to lower the replacement costs. -
Eco blank mode
The eco blank mode allows teachers to blank the projection screen whenever they need to direct their students' focus back on them - or simply when the projector is not in use. When activated, this special feature dims the lamp power automatically, lowering the total power consumption by 70%. -
No source detected mode
The automatic switch to Eco Blank Mode after the projector is turned on for over three minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp. -
0.5W in standby mode
When inactive, the MS619ST keeps power consumption to a minimum with 0.5W standby power, achieving what was once a challenge for ealier projector models. This technological advancement in energy saving certainly helps extend the projector lamp life and lower energy costs. -
Audio pass through
With the built-in speaker, the MS619ST can be used as an audio system when it's on the standby mode. This saves you the trouble as well as the extra budget for getting a separate audio system. -
Blu-ray Full HD 3D supported
BenQ MS619ST is built with latest DLP technology to support 3D functionality, allowing schools to bring an immersive learning experience to their students with a simple preparation of 3D glasses and 3D content from your blu-ray player. -
Zero space constraints
Just imagine the freedom of having the same projection quality with half the required distance! You'll have better flexibility in choosing your projection locations! That's the magic of short-throw! -
Zero eye-blinding lights
The short-throw projection distance keeps the projector light from shinning directly into your eyes, allowing you to keep your focus on your audience. -
Zero disruptions
Say goodbye to the annoying shadows. With a projection distance this close, you can move freely without worrying about obstructions between the projector and the screen! -
Quick installation
By pressing Quick Intall key on the remote control, installer can quickly acces to installation related functions in the OSD menu. -
Upper lamp door for easy lamp access
The upper lamp door is designed for it managers to replace the projector lamp safely and quickly. should the projector lamp go out in the middle of the class, it can be replaced without delaying the class. -
Auto power off
Automatic power off after the projector is turned on for over thirty minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp. -
Auto blank for safe use
Auto blank is an eye protection feature designed to ensure safe use. It enables the MS619ST to detect movements within 20 centimeters in front of the lens and cut off the projection light automatically. -
Wireless display with laptop, tablets and smart phones
Insert a WiFi dongle into the USB flash drive slot to display contents from your PC, MAC, iPhone and iPad to MS619ST through wireless display feature. -
ecoFACTS label
ecoFACTS can tell you how eco-friendly BenQ products are! Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products! ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products.
- BenQ MS619ST - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3000 lumens
- Contrast Ratio
- 13000:1
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 196 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 305 Watt
- 28.73 cm x 23.26 cm x 11.44 cm
- 2.6 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 13000:1
- Image Size
- 762 cm
- Throw Ratio
- 0.9 - 1.08:1
- Digital Zoom Factor
- 2x
- Resolution
- SVGA - SVGA (800 x 600) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- UHP 196 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- 6-segment colour wheel, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, BrilliantColor, NVIDIA 3D Vision, DLP 3D Ready, 3D Color Management, VIDI Lighting Technology, SmartEco Technology, DLP Link, MyScreen, Eco Blank
Lens
- Lens Aperture
- F/2.6 - 2.78
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB - mini-USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security Slot Type
- Kensington security slot
- Voltage Required
- 305 Watt
- Power Consumption Stand by
- 0.5 Watt
- 28.73 cm
- 23.26 cm
- 11.44 cm
- 2.6 kg
- 0 °C
- 40 °C
- Sound Emission
- 33 dB/mW
- Sound Emission (Economic Mode)
- 28 dBA
