Offering lower TCO and optimized projection through dynamic power saving, uncompromised brightness, exquisite picture quality and optimized lamp life-SmartEco Technology has perfected what a DLP projector can do. With this innovation, schools and corporates are able to save up to 70% of lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid viewing experience into every presentation.
Lampsave mode
Projector lamp replacement costs make up the biggest part of the total cost of projector ownership. The LampSave Mode is designed to adjust the lamp power dynamically by content brightness level to extend projector lamp life significantly by 50%! The lamp replacement frequency is also reduced by up to 50% to lower the replacement costs. -
Blu-ray Full HD 3D Supported
BenQ MS527 is built with latest DLP technology to support 3D functionality, allowing schools to bring an immersive learning experience to their students with a simple preparation of 3D glasses and 3D content from your blu-ray player. -
BenQ DLP projectors perfectly long lasting picture quality with DLP Projection Technology
Digital Light Processing (DLP), awarded 2015 Academy Award of Merit (Oscar statuette), is the leading projection technology used in 90% of world's digital cinemas and 100% of IMAX theaters. With DLP dominating the worldwide projector market with over 50% share, BenQ is today the bestselling DLP projector brand, delivering unmatched world-class performance. -
Long lasting
The incredibly durable micro-mirrors of the DLP chip and the nearly-sealed DLP engine design mean that BenQ DLP Projectors stand the test of time without any loss in picture quality. Eliminating dust buildup and heat damage, BenQ projectors shine year after year and look as good as new with a simple lamp change. -
Razor-sharp
Critically acclaimed for industry-leading high contrast, BenQ DLP Projectors also produce the most crisply defined sharpness for crystal-clear details and legible text by maximizing the fill ratio of individual pixels and employing exclusive BenQ SmartEco Technology.
- BenQ MS527 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 13000:1
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 270 watt
- 28.3 cm x 22.2 cm x 9.5 cm
- 1.9 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 13000:1
- Image Size
- 152 cm - 762 cm
- Throw Ratio
- 1.96 - 2.15:1
- Resolution
- SVGA - SVGA (800 x 600)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 190 watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- sRGB colour profile, ecoFACTS, SmartEco Technology, Dynamic Mode, SmartEco Mode, LampSave Mode
Lens
- Lens Aperture
- F/2.56-2.68
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 watt
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security Slot Type
- Kensington security slot
- Voltage Required
- 270 watt
- Power Consumption Stand by
- 0.5 watt
- 28.3 cm
- 22.2 cm
- 9.5 cm
- 1.9 kg
- Sound Emission
- 33 dBA
- Sound Emission (Economic Mode)
- 28 dBA
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.02 |
