Featuring a brightness of 3000 ANSI lumens and a high contrast ratio of 13000:1, the cost-effective and eco-friendly MS504 offers a stunning full-screen presentation with the finest details regardless of the ambient light level.
Power saving, eco friendly: world-leading SmartEco technology for a greener environment
As the first DLP brand to incorporate ImageCare technology into its projector lamp system, BenQ has taken a further leap, developing its own SmartEco technology to perfect what DLP can do for energy saving in the 21st century classroom. Built with this invention, the MS504 brings together uncompromised brightness, exquisite picture quality and optimized lamp life through innovative features. -
SmartEco mode
The SmartEco mode, which cleverly adjusts the lamp power to maximize power saving by delivering the best contrast and brightness performance using only as much light as needed. -
LampSave mode
Projector lamp replacement costs make up the biggest part of the total cost of projector ownership. The LampSave mode is designed to adjust the lamp power dynamically by content brightness level to extend projector lamp life! The lamp replacement frequency is also reduced to lower the replacement costs. -
Eco Blank mode
The Eco Blank mode allows teachers to blank the projection screen whenever they need to direct their students' focus back on them - or simply when the projector is not in use. When activated, this special feature dims the lamp power automatically, lowering the total power consumption. -
No source detected mode
The automatic switch to Eco Blank mode after the projector is turned on for over three minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp. -
0.5W in standby mode
When inactive, the MS504 keeps power consumption to a minimum with 0.5W standby power, achieving what was once a challenge for ealier projector models. This technological advancement in energy saving certainly helps extend the projector lamp life and lower energy costs. -
Audio pass through
With the built-in speaker, the MS504 can be used as an audio system when it's on the standby mode. This saves you the trouble as well as the extra budget for getting a separate audio system. -
Hassle-free projector maintenance: upper lamp door for easy lamp access
The upper lamp door is designed for it managers to replace the projector lamp safely and quickly. Should the projector lamp go out in the middle of the class, it can be replaced without delaying the class. -
Teaching template
To make your teaching job easier, BenQ has added the teaching template function to the MS504. Now, with four different line pattern designs to choose from - Letter Formation, Musical Staff, Worksheet and Coordinate Chart, you can easily write or draw on whiteboards as well as blackboards without the need of drawing lines or charts. -
Quick installation
By pressing Quick Install key on the remote control, installer can quickly access to installation related functions in the OSD menu. -
ecoFACTS label: ecoFACTS can tell you how eco-friendly BenQ products are
Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products! ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products.
- BenQ MS504 - DLP projector - portable
- DLP projector
- Built-in Devices
- Speaker
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 13000:1
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 270 Watt
- 28.3 cm x 22.2 cm x 9.5 cm
- 1.8 kg
- DLP projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 13000:1
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.86 - 2.04:1
- Resolution
- SVGA - SVGA (800 x 600) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- sRGB colour profile, AudioPass, ecoFACTS, SmartEco Technology, ImageCare Technology, Eco Blank
Lens
- Lens Aperture
- F/2.56-2.8
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, component video, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x USB - mini-USB Type B , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Voltage Required
- 270 Watt
- Power Consumption Stand by
- 0.5 Watt
- 28.3 cm
- 22.2 cm
- 9.5 cm
- 1.8 kg
- Sound Emission
- 33 dBA
- Sound Emission (Economic Mode)
- 28 dBA
