Featuring a Full HD native resolution, a brightness of 3000 ANSI lumens and a high contrast ratio of 10000:1, the MH680 offers a stunning full-screen presentation with the finest details regardless of the ambient light level.
Power saving, eco friendly
Offering lower maintenance cost, uncompromised brightness, exquisite picture quality and optimized lamp life - BenQ's SmartEco technology has perfected what a DLP projector can do in business projector. With this special innovation, you are able to save up to 70% of lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid picture quality in every meeting room. -
SmartEco mode
The SmartEco mode, which cleverly adjusts the lamp power to maximize power saving by delivering the best contrast and brightness performance using only as much light as needed. -
No source detected mode
The automatic switch to eco blank mode after the projector is turned on for over three minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp. -
0.5 W in standby mode
When inactive, the MH680 keeps power consumption to a minimum with 0.5 W standby power, achieving what was once a challenge for ealier projector models. This technological advancement in energy saving certainly helps extend the projector lamp life and lower energy costs. -
Auto power off
Automatic power off after the projector is turned on for over 30 minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp. -
Premium Full HD 1080p resolution
With the BenQ MH680, business presentations will never look the same! The MH680 supports multiple video formats including 480p, 576p, 720p, 1080i and 1080p - giving you the flexibility to present in the video formats with Full HD quality. The BenQ MH680 sets a standard of video presentation that delivers 5x more detail than traditional 480p projectors. -
Blu-ray Full HD 3D supported
BenQ MH680 is built with DLP technology to support 3D functionality, allowing schools to bring an immersive learning experience to their students with a simple preparation of 3D glasses and 3D content from your blu-ray player. -
Audio pass through
With the built-in speaker, the MH680 can be used as an audio system when it is on the standby mode. This saves you the trouble as well as the extra budget for getting a separate audio system. -
Wireless display
Insert a Wi-Fi dongle into the USB flash drive slot to display contents from your PC, MAC, iPhone, iPad or Android Pad to MH680 through wireless display feature, make your presentation ease and confident. -
USB display
USB display offers the Plug-and-Play convenience of USB connection - with automatic resolution detection for the best image presentation and extension support for simultaneous multi-projection display. -
PC-less teaching
USB drive display allows teachers to teach light with a USB flash drive. All they need to do is save the files they need onto a USB flash drive and insert it in the MH680 to start teaching. -
Upper lamp door for easy lamp access
The upper lamp door is designed for IT managers to replace the projector lamp safely and quickly. should the projector lamp go out in the middle of the class, it can be replaced without delaying the class. -
ecoFACTS label
ecoFACTS can tell you how eco-friendly BenQ products are! Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products! ecoFACTS declares BenQ's great efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products.
- BenQ MH680 - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Built-in Devices
- Speaker
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 10000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 210 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 315 Watt
- 31.2 cm x 24.4 cm x 10.4 cm
- 2.6 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 10000:1
- Image Size
- 114 cm - 762 cm
- Throw Ratio
- 1.15 - 1.5:1
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 210 Watt
- Bulb life cycle
- OSD Languages
- English, German, French, Italian, Spanish
- 6-segment colour wheel, BrilliantColor, SmartEco Technology
Lens
- Lens Aperture
- F/2.59-2.87
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin mini-USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- TUV GS
- Voltage Required
- 315 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.2 cm
- 24.4 cm
- 10.4 cm
- 2.6 kg
- Limited warranty - lamp - 1 year / 2000 hours , Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 28 dB
