BenQ GW2760HS 27" 1920x1080 8ms VGA DVI-D HDMI LED Monitor
Quicklinx: 9G7CWS00 Mfr#: 9H.L9NLB.QBE
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
Select:
£163.29 ex VAT
£195.94 inc VAT
Built to bring you the ultimate personal visual entertainment, the BenQ GW2760HS is certainly one of a kind! Featuring the slim bezel, flicker-free backlight, speakers, 3000:1 native contrast, 20M:1 dynamic contrast ratio, and true 8-bit panel performance with deep blacks and minimized light leakage, this VA LED monitor refreshes your view with truly fantastic colors and details. It also gives you optimal eye comfort with BenQ's exclusive eye-caring technolog. The HDMI connectivity leads the path to a whole level of multimedia enjoyment.
  • Fashionably slim for your viewing pleasure
    Exceptionally built to please your eyes with fantastic colors and details from every viewing angle, as well as a beautiful slim design, the GW2760HS Full HD VA LED monitor is everything you'll need for essential home and office use and more! Get ready to enjoy luxury premium visual enjoyment everyday with BenQ!
  • Slim and beautiful with more to please the eye
    A stunning work of art, the GW2760HS is fashioned with a slim bezel and slim chassis to create a simple, compact look that complements every contemporary home and office. A slim bezel design not only saves space but also enables a nearly seamless view in multi-display configurations.
  • Flicker-free backlight for visual pleasure
    The GW2760HS is upgraded to eliminate flickering at all brightness levels, effectively reducing eye fatigue.
  • Reading mode for an optimized reading experience
    For a more comfortable reading experience, BenQ has adjusted the monitor's color temperature, brightness, contrast ratio and sharpness to create the reading mode which simulates the look of printed paper to help reduce the eye discomfort typically caused by prolonged and focused use of eyes on computer monitors.
  • Improved eco mode for higher energy efficiency
    The improved eco mode adjusts the backlight brightness level to ensure the highest display quality is presented to you with the highest energy efficiency. This intelligent mode reduces at least 37% of the power consumed by document viewing, Internet browsing and emailing and up to 44% of the power consumed by gaming.
  • 3000:1 native contrast ratio and 20M:1 dynamic contrast ratio for depth and definition
    The GW2760HS comes with an ultra-high native contrast ratio of 3000:1 and dynamic contrast ratio of 20M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • Color Shift-free technology
    Enjoy perfect skin tone and image color presentation from a wide-viewing angle of 178°/178°! The Color Shift-free technology reduces the visibility of color washout, or color shift, between normal and oblique viewing angles, giving you consistent color uniformity and true color definition from left, right, above and below.
  • Perfecting your audiovisual enjoyment with speakers
    Whether you're listening to music or watching your favorite film, simply turn on the speakers to experience the audiovisual fun!
  • HDMI multimedia interface
    The HDMI high-speed multimedia interface makes these monitors incredibly convenient to use - now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future.
  • Full HD 1080p 16:9 visual perfection
    The BenQ GW2760HS supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing.
  • Superior response time
    Enjoy high dynamic videos without ghosting or other artifacts with 4 ms GTG response time.
  • Senseye 3 visual solution to your everyday viewing needs
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its pre-set viewing modes - standard, movie, game, photo, sRGB, reading, and eco - with the eco mode especially designed to save power and money.
BenQ GW2760HS - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
56 kWh
Power Consumption (On mode)
38 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Glossy black
70.2 cm x 13.1 cm x 44.6 cm
4.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TUV
3-year warranty
Display Type
Energy Class
Class B
56 kWh
38 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour temperature, phase
HDCP, Senseye 3 Technology
Glossy black
4.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
Audio line-in , HDMI (HDCP) , DVI-D (HDCP) , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
TUV
Security Slot Type
Kensington security slot
Power Supply
Internal
AC 120/230 V (47 - 63 Hz)
27 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
ENERGY STAR Certified
Limited warranty - 3 years - on-site
5 °C
20 - 90% (non-condensing)
BenQ GW2760HS 27 Bundle deal on BenQ GW2760HS 27" 1920x1080 8ms VGA DVI-D HDMI LED Monitor
£262.46
Diagonal Size: 27in
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 150 - 300
