BenQ GW2750HM 27" LED 1920X1080 16:9 2MS
Quicklinx: 8331WS00 Mfr#: 9H.L8NLB.QBE
Built to bring you the ultimate personal visual entertainment, the BenQ GW2750HM is certainly one of a kind! Featuring the ultra-high 5000:1 native contrast, 20 M:1 dynamic contrast ratio, and true 8-bit panel performance with deep blacks and minimized light leakage, this VA LED monitor refreshes your view with truly fantastic colors and details. And, its HDMI connectivity leads the path to a whole level of multimedia enjoyment.
  • VA LED leads the way
    Built with the dream combination of LED with VA panel, GW series is bound to bring a whole visual experience and enjoyment to you with truly authentic colors, deeper blacks, higher contrast and sharper details.
  • 5000:1 ultra high native contrast ratio for better image depth and definition
    The GW2750HM comes with an ultra-high native contrast ratio of 5000:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • Perfecting your audiovisual enjoyment with speakers
    Whether you're listening to music or watching your favorite film, simply turn on the speakers to experience the audiovisual fun!
  • HDMI multimedia interface
    The HDMI high-speed multimedia interface makes these monitors incredibly convenient to use - now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future.
  • Superior response time
    Enjoy high dynamic videos without ghosting or other artifacts with 4 ms GTG response time.
  • Senseye 3 Visual solution to your everyday viewing needs
    Experience the truest colors of the world with the BenQ Senseye Human Vision Technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the eco mode especially designed to save power and money.
  • ENERGY STAR qualified
    The GW2750HM complies with the requirement of ENERGY STAR Program for Computer Monitors. Now you can enjoy saving energy and money as well as keeping the Earth lookin' great!
BenQ GW2750HM - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Stereo speakers
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
5000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
AC 120/230 V (47 - 63 Hz)
Glossy black
65.4 cm x 19.1 cm x 48.9 cm
5.5 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
27"
Built-in Devices
Stereo speakers
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour temperature, phase
HDCP, Senseye 3 Technology
Glossy black
65.4 cm x 19.1 cm x 48.9 cm - with stand
5.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Audio line-in , HDMI , DVI-D (HDCP) , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 65.4 cm - depth: 19.1 cm - height: 48.9 cm , Without stand - width: 65.4 cm - depth: 6.5 cm - height: 39.7 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 2 years - pick-up and return
5 °C
20 - 90%
