A perfect embodiment of The Bauhaus' "less is more" minimalism design philosophy, the GW2470HM is a delightful complement to almost any modern space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ's exclusive eye-caring technology. The GW2470HM is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business.
Exquisitely refined to complement your home and office, every detail of the GW2470HM exemplifies the highest craftsmanship. The T-shaped base surface in the front is brushed with hairline treatment and adorned by a rectangular-shaped glossy black embellishment. The housing styled in black is fashioned with delicate patterns in the back to subtly catch the eye. With this classic minimalistic wonder, the GW2470HM is everything you seek for the ultimate sophistication.
Everyday enjoyment for leisure and business
A perfect embodiment of The Bauhaus’ “less is more" minimalism design philosophy, the GW2470HM is a delightful complement to almost any modern space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ’s exclusive eye-caring technology. The GW2470HM is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business. -
Designed simply for the ultimate sophistication
Exquisitely refined to complement your home and office, every detail of the GW2470HM exemplifies the highest craftsmanship. The T-shaped base surface in the front is brushed with hairline treatment and adorned by a rectangular-shaped glossy black embellishment. The housing styled in black is fashioned with delicate patterns in the back to subtly catch the eye. With this classic minimalistic wonder, the GW2470HM is everything you seek for the ultimate sophistication. -
TÜV Rheinland Certification
GW2470HM Eye-care monitor has been certified by TÜV Rheinland for Flicker-free and low blue light, the world’s leading provider of technical, safety and certification services, as truly friendly to the human eye. BenQ, the first brand of Eye-care monitor in the world, as a permanent addition to monitor product line, stressing on commitment to safeguard eye vision and to always act first on offering the most comfortable and enjoyable viewing experience. -
Flicker-free backlight for visual pleasure
The Flicker-free Technology eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 200 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ Flicker-free monitor. -
Low Blue light
Unique BenQ Low Blue Light Technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation. -
3000:1 native contrast ratio for color depth and definition
An ultra-high native contrast of 3000:1, which is three times of that of general panels, adds astonishing color depth and definition to darkened, complex images with the greatest subtlety and clarity. With a native contrast ratio this high, you can expect an infinite dynamic contrast ratio that far exceeds your expectations.
- BenQ GW2470HM - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class A
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23 W
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 4 ms (grey-to-grey), 16 ms (tr - tf)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Textured black, glossy black
- 55.3 cm x 18.912 cm x 42.51 cm
- 4.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 34 kWh
- Diagonal Size
- 23.8"
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, ecoFACTS Label, Colour Temperature Selection, 72% NTSC colour gamut
- 55.3 cm x 18.912 cm x 42.51 cm - with stand
- 4.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- DVI , HDMI , VGA , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Cables Included
- 1 x VGA cable - 1.5 m , 1 x HDMI cable - 1.5 m
- Backlight Life
- 30,000 hours
- MTBF
- 60,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 23 W
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- On / Off Switch
- No
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 40 °C
