BenQ GW2470HL 23.8" 1920x1080 4ms HDMI VGA LED Monitor
Quicklinx: DTWYWS00 Mfr#: 9H.LG6LB.QBU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 4ms
Interfaces: HDMI, VGA (HD-15)
More than 50 in stock
£78.09 ex VAT
£93.70 inc VAT
Embodying "less is more" minimalist design, GW2470HL delightfully complements any modern space. Every aspect of form and function is reduced to unify simplicity and aesthetics. Enhancing visual pleasure and optimal eye comfort with BenQ exclusive eye-care technology, GW2470HL celebrates minimalism and modern lifestyles as a gateway to everyday enjoyment for business and leisure.
  • Minimal slim bezel design for ultimate sophistication
    Exquisitely refined for home and office, GW2470HL offers expansive views with minimally obtrusive slim bezel design.
  • Low Blue Light Plus technology
    Low Blue Light Plus technology filters out the shorter, higher energy blue-violet radiation (420~455nm) which is harmful to the eyes while the remaining beneficial blue turquoise light (455~480nm) remains. The blue spectrum light produced by regular computer screens is a leading cause of eye fatigue. BenQ's GW2470HL comes equipped to help prevent the eye fatigue associated with blue spectrum light. With adjustable low blue light levels, you can increase your viewing comfort especially after long hours of usage.
  • Flicker-free
    Flicker-free eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 250 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ flicker-free monitor.
  • 3000:1 ultra-high native contrast for depth and definition
    Ultra-high 3000:1 native contrast, 3X higher than standard panels, adds astonishing color depth and definition to complex dark images with exquisite subtlety and clarity. High native contrast also enables infinite dynamic contrast to far exceed the highest expectations.
  • 178°/178° wide viewing angles
    Advanced VA (Vertical Alignment) panel technology delivers truly authentic colors and ultra-sharp details from left, right, above and below with 178°/178° viewing angles for an unsurpassed viewing experience.
  • 8-bit color display
    With the ability to render 16.7 million color shades simultaneously, you can expect true colors, silky transitions and impeccable image quality.
Display Type
Energy Class
Class B
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
Diagonal Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 2000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Hungarian, Czech, Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Arabic, Romanian, Japanese, Chinese, Korean, New Zealand English
HDCP, Advanced Motion Accelerator (AMA) technology, 72% NTSC colour gamut, Dynamic Power Saving (DPS), Flicker Free technology, slim bezel design, 8-bit gamma, Brilliant Image Quality, K Locker, Low Blue Light Plus technology, Eye-Care Technology
55.3 cm x 18.9 cm x 42.5 cm
4.1 kg
VGA ¦ 2 x HDMI ¦ Headphones
Mechanical
Display Position Adjustments
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA 100 x 100 mm
TUV Rheinland Low Blue Light Certification
Security Slot Type
Kensington security slot
23 Watt
Power Consumption Stand by
0.5 Watt
Shipping Weight
5.6 kg
Environmental Standards
ENERGY STAR Certified
BenQ GW2470HL 23.8 Bundle deal on BenQ GW2470HL 23.8" 1920x1080 4ms HDMI VGA LED Monitor
£177.26
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 50 - 100
