BenQ GW2470HL 23.8" 1920x1080 4ms HDMI VGA LED Monitor
Quicklinx: DTWYWS00 Mfr#: 9H.LG6LB.QBU
Embodying "less is more" minimalist design, GW2470HL delightfully complements any modern space. Every aspect of form and function is reduced to unify simplicity and aesthetics. Enhancing visual pleasure and optimal eye comfort with BenQ exclusive eye-care technology, GW2470HL celebrates minimalism and modern lifestyles as a gateway to everyday enjoyment for business and leisure.
  • Everyday enjoyment for leisure and business
    A perfect embodiment of 'less is more' minimalism design philosophy, the GW2470HL is a delightful complement to almost any modern space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy visual pleasure and optimal eye comfort with BenQ's exclusive Eye-Care technology. The GW2470HL is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business.
  • Low Blue Light Plus technology
    Low Blue Light Plus technology filters out the shorter, higher energy blue-violet radiation which is harmful to the eyes while the remaining beneficial blue turquoise light remains.
  • Flicker-free technology
    Flicker-free technology eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 200 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ Flicker-free monitor.
  • 3000:1 ultra-high native contrast for depth and definition
    An ultra-high native contrast of 3000:1, which is three times of that of general panels, adds astonishing color depth and definition to darkened, complex images with the greatest subtlety and clarity. With a native contrast ratio this high, you can expect an infinite dynamic contrast ratio that far exceeds your expectations.
  • 8-bit display
    With the ability to render 16.7 million color shades simultaneously, you can expect true color performance, silky transitions and impeccable image quality.
  • 178°/178° wide-viewing angles
    VA panels bring truly authentic colors and ultra-sharp details from left, right, above and below to your eyes with a wide-viewing angle of 178°/178°. Viewing, as you know it, will never be the same.
BenQ GW2470HL - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 2000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Voltage
55.3 cm x 18.9 cm x 42.5 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV Rheinland Low Blue Light Certification
Display Type
Energy Class
Class B
37 kWh
Diagonal Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Hungarian, Czech, Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Arabic, Romanian, Japanese, Chinese, Korean, New Zealand English
HDCP, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Flicker Free technology, slim bezel design, 8-bit gamma, Brilliant Image Quality, K Locker, Low Blue Light Plus technology, Eye-Care Technology, 72% NTSC colour gamut
4.1 kg
VGA , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA 100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
25 W
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.5 Watt
Shipping Weight
5.6 kg
Sustainability Information
ENERGY STAR Certified
