Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL955A LED monitor is the perfect choice for you! Featuring a dynamic contrast ratio of 12M:1, response time of 5ms, and BenQ's exclusive Senseye Technology, this 18.5"W 16:9 LED monitor delivers you the visual enjoyment with best value.
LED leads the way
LED backlighting offers significant advantages over the CCFL technology used in older LED monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants. -
12M: 1 ultra high dynamic contrast for depth and definition
The GL955A comes with an ultra-high dynamic contrast ratio of 12M: 1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. -
Superior response time
Enjoy high dynamic videos without ghosting or other artifacts with 5ms response time. -
Senseye technology
Experience the truest colors of the world with the BenQ Senseye Human Vision Technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - Standard, Movie, Game, Photo, sRGB, and Eco - with the Eco Mode especially designed to save power and money. -
Save energy to save up
Energy-efficient LED panel provides greater power saving by 14.3% and with the help of Eco Mode, you can save up to 39.3%.
- BenQ GL955A - LED monitor - 18.5"
- LED-backlit LCD monitor - 18.5"
- Panel Type
- TN
- Native Resolution
- 1366 x 768
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 12000000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- VGA
- Tilt
- Glossy black
- 45.9 cm x 16.4 cm x 36.2 cm
- 2.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Diagonal Size
- 18.5"
- Panel Type
- TN
- Native Resolution
- 1366 x 768
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 50
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- Senseye Human Vision Technology, Senseye 3 Technology
- Glossy black
- 2.8 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Power Consumption (Typical)
- 11 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
Sustainability Information
- ENERGY STAR Certified
