BenQ GL955A 18.5" 1366x768 5ms VGA Black Monitor
Quicklinx: 8LCLWS00 Mfr#: 9H.L94LA.T8E
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL955A LED monitor is the perfect choice for you! Featuring a dynamic contrast ratio of 12M:1, response time of 5ms, and BenQ's exclusive Senseye Technology, this 18.5"W 16:9 LED monitor delivers you the visual enjoyment with best value.
  • LED leads the way
    LED backlighting offers significant advantages over the CCFL technology used in older LED monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants.
  • 12M: 1 ultra high dynamic contrast for depth and definition
    The GL955A comes with an ultra-high dynamic contrast ratio of 12M: 1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • Superior response time
    Enjoy high dynamic videos without ghosting or other artifacts with 5ms response time.
  • Senseye technology
    Experience the truest colors of the world with the BenQ Senseye Human Vision Technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - Standard, Movie, Game, Photo, sRGB, and Eco - with the Eco Mode especially designed to save power and money.
  • Save energy to save up
    Energy-efficient LED panel provides greater power saving by 14.3% and with the help of Eco Mode, you can save up to 39.3%.
BenQ GL955A - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Panel Type
TN
Native Resolution
1366 x 768
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 12000000:1 (dynamic)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
VGA
Display Position Adjustments
Tilt
Glossy black
45.9 cm x 16.4 cm x 36.2 cm
2.8 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
18.5"
Panel Type
TN
Native Resolution
1366 x 768
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Horizontal Viewing Angle
90
Vertical Viewing Angle
50
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
2.8 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Power Supply
Internal
Power Consumption (Typical)
11 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Power Consumption Sleep
0.3 Watt
Sustainability Information
ENERGY STAR Certified
