Whether you are catching up on the show on the Internet or viewing documents, the BenQ GL2760H LED monitor is the perfect choice for you in style! Featuring dynamic ratio of 12M:1, Flicker-free, and response time of 2 ms, this 27" 16:9 LED monitor delivers you the audiovisual enjoyment.
LED leads the way
LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast and no light leakage, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants. -
Flicker-free backlight for visual pleasure
The GL2760H is upgraded to eliminate flickering at all brightness levels, effectively reducing eye fatigue. -
12M: 1 ultra high dynamic contrast for depth and definition
The GL2760H comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the bright white to the darkest black, is perfectly rendered to deliver the clear, smooth picture performance during movies and video games. -
Fast 2 ms GTG response time
Fast response time of 2 ms GTG means speed without the smear. Fast-moving action and dramatic transitions will be rendered smoothly - without smearing or ghosting. Control your gaming destiny and don't leave it in the hands of sluggish display. -
Senseye technology
Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and Eco - with the Eco mode especially designed to save power and money. -
ecoFACTS label
ecoFACTS can tell you how eco-friendly BenQ products are! Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products! ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products.
- BenQ GL2760H - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 45 kWh
- Power Consumption (On mode)
- 31 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V
- Glossy black
- 64.1 cm x 21.465 cm x 48.808 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- HDCP 1.4
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 45 kWh
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Pixel Per Inch
- 82
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, colour temperature, phase, clock
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Romanian, Japanese, Serbo-Croatian
- HDCP, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Flicker Free technology, K Locker, Low Blue Light technology, 72% NTSC colour gamut
- Glossy black
- 5.5 kg
- VGA , DVI-D (HDCP) , HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- HDCP 1.4
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 31 W
- Power Consumption (Typical)
- 29 Watt
- On / Off Switch
- No
- Shipping Width
- 71.5 cm
- Shipping Depth
- 13.2 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 7.4 kg
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Limited warranty - 3 years
