Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2460 LED monitor is the perfect choice for you in style! Featuring Senseye Human Vision technology with optimized eco mode and reading mode, a dynamic ratio of 12M:1, and 2 ms GtG response time, this 24" W 16:9 LED monitor delivers every image detail with the best viewing quality.
Brilliant image quality
LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants. -
An integral part of your home and workplace decor
GL60 Series blends perfectly with any decor, adding a hint of low-key elegance to your living space with its high-gloss frame and base stand streamlined by a curvaceous neck that creates stunning visual fluidity. Beautiful from any angle, the back of the GL2460 is carbon fiber patterned to recreate the powerful drive of a racing car and energize their whole appearance. Incorporating a 16 mm slim bezel display, GL60 Series creates a sophisticated look while keeping things nice and compact. You'll find multi-panel configuration for home entertainment or office viewing use much simpler with less distraction from the monitor frame. -
Reading mode for an optimized reading experience
For a more comfortable reading experience, BenQ has adjusted the monitor's color temperature, brightness, contrast ratio and sharpness to create the reading mode which simulates the look of printed paper to help reduce the eye discomfort typically caused by prolonged and focused use of eyes on computer monitors. -
Improved eco mode for higher energy efficiency
The improved eco mode adjusts the backlight brightness level to ensure the highest display quality is presented to you with the highest energy efficiency. This intelligent mode reduces at least 37% of the power consumed by document viewing, Internet browsing and emailing and up to 44% of the power consumed by gaming. -
12M:1 dynamic contrast ratio for color depth and definition
The GL2460 comes with a dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. -
Full HD 1080p 16:9 visual perfection
The BenQ GL2460 supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing.
- BenQ GL2460 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V
- Glossy black
- 56.5 cm x 19.4 cm x 43.4 cm
- 4.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Display Type
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- Eco-Mode, Advanced Motion Accelerator (AMA) technology, Senseye Human Vision Technology, Senseye 3 Technology
- Glossy black
- 56.5 cm x 19.4 cm x 43.4 cm - with stand
- 4.3 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 23 Watt
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
