Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2450 LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1, Senseye Human Vision technology, 5ms response time and DVI connector, this 24" W 16:9 LED monitor delivers every image detail with the best viewing quality.
LED leads the way
LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants. -
12M:1 ultra high dynamic contrast for depth and definition
The GL2450 comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. -
Full HD 1080p 16:9 visual perfection
The BenQ GL2450 supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing. -
Superior response time
Enjoy high dynamic videos without ghosting or other artifacts with 5ms response time. -
Senseye technology
Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the Eco Mode especially designed to save power and money. -
Save energy to save up
Energy-efficient LED panel provides greater power saving by 14.3% and with the help of eco mode, you can save up to 39.3%. -
Win 7 compatible
The GL2450 has passed Windows 7 certification and are fully compatible with Windows 7 color systems. Plug in the GL2450 to your computer, and Windows 7 will recognize it instantly, making setup and connection effortless. -
ecoFACTS label
ecoFACTS can tell you how eco-friendly BenQ products are! -
Energy Star qualified
The GL2450 complies with the requirement of ENERGY STAR program for computer monitors, Version 5.0. Now you can enjoy saving energy and money as well as keeping the Earth looking great!
- BenQ GL2450 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 90 - 264 V
- Glossy black
- 57.9 cm x 17.9 cm x 43.6 cm
- 4.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV Rh
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, colour balance, saturation, gamma correction, graphic / text mode, colour temperature, phase, clock, hue
- HDCP, Senseye Human Vision Technology, Senseye 3 Technology, Flicker Free technology, ecoFACTS Label
- Glossy black
- 4.1 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x power cable , 1 x VGA cable
- TUV Rh
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 90 - 264 V
- Power Consumption (Typical)
- 34 Watt
- Power Consumption Stand by
- 0.3 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £6.83 |
