Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2250HM LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1, speakers, response time of 2ms and DVI and HDMI connector, this 21.5"W 16:9 LED monitor delivers you the audiovisual enjoyment.
LED leads the way
LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants. -
12M:1 ultra high dynamic contrast for depth and definition
The GL2250HM comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. -
Perfecting your audiovisual enjoyment with speakers
Whether you're listening to music or watching your favorite film, simply turn on the speakers to experience the audiovisual fun! -
HDMI multimedia interface
The latest HDMI high-speed multimedia interface makes these monitors incredibly convenient to use - now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future. -
Superior response time
Enjoy high dynamic videos without ghosting or other artifacts with 2ms GTG response time. -
Senseye 3 visual solution to your everyday viewing needs
Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the eco mode especially designed to save power and money. -
Save energy to save up
Energy-efficient panel provides greater power saving by 14.3% when speakers are on, in comparison with G2222HD. -
Win 7 compatible
The GL2250HM has passed Windows 7 certification and are fully compatible with Windows 7 color systems. Plug in the GL2250HM to your computer, and Windows 7 will recognize it instantly, making setup and connection effortless. -
ecoFACTS label
ecoFACTS can tell you how eco-friendly BenQ products are! -
Energy Star qualified
The GL2250HM complies with the requirement of Energy Star program for computer monitors, version 5.1. Now you can enjoy saving energy and money as well as keeping the Earth looking great!
- BenQ GL2250HM - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class B
- Energy Consumption per Year
- 36 kWh
- Power Consumption (On mode)
- 25 W
- Stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray), 5 ms (typical)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 52.3 cm x 17.4 cm x 40 cm
- 3.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class B
- 36 kWh
- Diagonal Size
- 21.5"
- Built-in Devices
- Stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- HDCP, Senseye Human Vision Technology, Senseye 3 Technology
- 3.8 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- Cables Included
- 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 25 W
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.3 Watt
- On / Off Switch
- No
Sustainability Information
- ENERGY STAR Certified
