Product
BenQ GL2250 21.5" 1920 x 1080 2ms VGA DVI LED Monitor Glossy Black
Quicklinx: 7PM6WS00 Mfr#: 9H.L6VLA.TPE
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 2ms
Speakers: None
Interfaces: DVI, VGA (HD-15)
Select:
  • 21.5"
More than 50 in stock
£66.56 ex VAT
£79.87 inc VAT
Whether you're catching up on the Internet or viewing documents, the BenQ GL2250 LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12,000,000:1, Senseye Human Vision technology, 5 ms response time and DVI connector, this 21.5" 16:9 LED monitor delivers every image detail with the best viewing quality.
  • Brilliant image quality LED leads the way
    LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants.
  • 12,000,000:1 ultra high dynamic contrast for depth and definition
    The GL2250 comes with an ultra-high dynamic contrast ratio of 12,000,000:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • Full HD 1080p 16:9 visual perfection
    The BenQ GL2250 supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing.
  • Superior response time
    Enjoy high dynamic videos without ghosting or other artifacts with 5 ms response time.
  • Senseye 3 Visual Solution to your everyday viewing needs
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the eco mode especially designed to save power and money.
  • ENERGY STAR qualified
    The GL2250 complies with the requirement of ENERGY STAR program for computer monitors. Now you can enjoy saving energy and money as well as keeping the Earth lookin' great!
BenQ GL2250 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
25 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (rise+fall); 2 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
52.5 cm x 17.4 cm x 40 cm
3.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
TUV Bauart, TCO Displays 5.1
Display Type
Energy Class
Class B
36 kWh
25 W
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Senseye 3 Technology
Glossy black
3.7 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Power Supply
Internal
AC 90 - 260 V (47 - 63 Hz)
Power Consumption Stand by / Sleep
0.3 Watt
0.3 Watt
On / Off Switch
No
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
5 °C
20 - 90% (non-condensing)
BenQ GL2250 21.5 Bundle deal on BenQ GL2250 21.5" 1920 x 1080 2ms VGA DVI LED Monitor Glossy Black
£166.32
7PM6 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £103.98
7PM6 StarTech.com Articulating Monitor Arm In Stock £96.76
7PM6 StarTech.com Dual Monitor Stand In Stock £69.36
7PM6 StarTech.com Cubicle Monitor Hanger In Stock £43.02
7PM6 StarTech.com TV/Monitor Arm - Wallmount In Stock £62.08
Response Time: 2ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 50 - 100
