BenQ BL902TM 19" 1280x1084 5ms VGA DVI-D Speakers LED Monitor
Quicklinx: 9G6SWS00 Mfr#: 9H.L5FLA.DBE
With ergonomic design for work comfort and economic value of cost-effectiveness, the BL902TM is designed to fit your working needs. It features 130mm HAS, around-the-clock smart reminder, anti-glare display and speakers. Adopting recyclable plastic materials and greener packaging, this monitor is built to keep the Earth lookin' great!
  • World's leading expert in LED monitors
    BenQ - the world's leading LED monitor brand - has put together the perfect business solution. BL902TM monitor comes with LED backlight technology to offer economic value of cost-effectiveness and ecological considerations for protecting environment.
  • Anti-glare display
    A glare panel - whether it's caused by a direct or reflected light source - makes it a challenge for office workers to see clearly without straining their eyes. The BenQ BL series LED monitors feature an anti-glare, matt-finish display to keep distracting reflections to a minimum, so office workers can work through their day-to-day tasks with well-improved efficiency - squint-free!
  • Ultra-flexible height adjustment system (HAS)
    Tailor the height, tilt, pivot, stroke and swivel adjustment of each monitor to perfectly fit individual users! BenQ's ultra-flexible height adjustment system (HAS) offers an extensive range of monitor adjustments to keep office workers of all shapes and sizes comfortable and fit for every work situation.
  • Energy efficient and money saving
    The BenQ BL902TM is built with the LED backlight technology to cut down power consumption. LED backlighting is also known for its highly durable and stable performance on brightness and color presentation - which means an extended usable lifespan for your business solutions.
  • Built-in speakers
    BenQ has added built-in speakers to the BL902TM to boost the appeal of your business solutions! Not having to buy separate sound systems means you get to save up more money!
  • Recyclable plastic materials
    Built to successfully minimize waste and environmentally harmful pollution, the BenQ BL902TM monitors are coating-free and 100% recyclable - with 65% of the monitor frame made of recycled plastics.
  • Greener packaging
    The BenQ BL902TM comes with an extra green packaging for easier recycling. All materials used for packaging are EPS-free - with all PVC or foamed plastics replaced with recyclable paper cushion. Moreover, recycled paper is used for 80% packing to save forests.
  • Ultra-high dynamic contrast ratio
    An amazing 12,000,000:1 dynamic contrast ratio adds color depth and definition to darkened and complex visuals. Any image from the brightest white to the darkest black is perfectly rendered to deliver the most incredible picture performance.
  • Superior response time
    With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
BenQ BL902TM - BL Series - LED monitor - 19"
LED-backlit LCD monitor - 19"
Stereo speakers
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, swivel, tilt
41.9 cm x 22.3 cm x 43.2 cm
5.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Display Type
Diagonal Size
19"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, anti-glare, Senseye 3 Technology
41.9 cm x 22.3 cm x 43.2 cm - with stand
5.1 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DVI-D , Headphones , Audio line-in
Mechanical
Tilt Angle
25
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x audio cable , 1 x VGA cable , 1 x DVI cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Power Consumption (Typical)
25.8 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
