Designed to meet the rising demands for large-sized viewing and ultra-high definition, the BL2711U boasts a 27"W 4K2K display built with BenQ's advanced IPS technology, providing professionals in CAD/CAM, animation, video editing and graphic arts ultra-precise color rendition and over 300% working space to enhance their work efficiency and productivity.
- BenQ BL series BL2711U - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 82 kWh
- Power Consumption (On mode)
- 56 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Pixel Pitch
- 0.155 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DVI-D, DisplayPort
- Speakers
- Integrated
- Pivot (rotation), tilt
- Black, matte
- 63.9 cm x 24 cm x 55.1 cm
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, EN 60950, TUV Ergo, TCO Displays 6.0, ISO9241-307
- 3 years warranty
- Display Type
- Energy Class
- Class C
- 82 kWh
- 56 W
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Pixel Pitch
- 0.155 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, sharpness, colour balance, colour temperature
- HDCP, Senseye 3 Technology, Eco Light Sensor, Low Blue Light Mode, Flicker Free technology, CAD/CAM Mode, Auto Pivot, OSD controller
- Black, matte
- 63.9 cm x 24 cm x 55.1 cm - with stand
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 3 Watt
- DVI-D (dual link) , DisplayPort , 2 x HDMI , 2 x USB 2.0 , 2 x USB 3.0 , Headphones , Audio line-in
Mechanical
- Tilt Angle
- -5/+20
- Height Adjustment
- 140 mm
- Flat Panel Mount Interface
- 100 x 100 mm
- Cables Included
- 1 x network cable , 1 x HDMI cable , 1 x DVI cable , 1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB cable
- Power Supply
- Internal
- Voltage Required
- AC 90 - 264 V (47 - 63 Hz)
- 42 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- Without stand - width: 63.9 cm - depth: 7 cm - height: 38.5 cm
- ENERGY STAR Certified
- Limited warranty - 3 years - on-site
- 5 °C
- 40 °C
- 20 - 90%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 0.5m Select High Speed HDMI with Ethernet | In Stock | £5.73 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £15.61 |
C2G 10m Select High Speed HDMI with Ethernet | In Stock | £29.98 |
C2G 15m Select High Speed HDMI with Ethernet | In Stock | £40.60 |
C2G Pro HDMI to VGA Converter | In Stock | £46.06 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
