BenQ BL2710, the first tailored CAD/CAM monitor is the ultimate solution carefully designed to meet all demands of every professional working with PTC, SolidWorks, AutoCAD, Maya or other CAD/CAM software.
CAD/CAM monitor - never miss a line again
Featuring a 27" 2560 x 1440 WQHD Flicker-free screen, 100% sRGB, DP, HDMI and USB 3.0 ports, HAS with unique CAD/CAM mode, which easily handles work with complicated object wireframes, this CAD/CAM monitor is bringing you optimal and holistic experience that turns your job into enjoyment. -
27" big screen and 2560 x 1440 WQHD high resolution
With a 2560 x 1440 WQHD resolution you can enjoy over 77% more work space and higher ppi compared to conventional 1920 x 1080 FHD monitors. Having the extra working space means less scrolls for zooming in and out, and the higher ppi gives you a sharper and more precise viewing experience. -
CAD/CAM mode for precision design
The unique CAD/CAM mode is specially designed to enhance work efficiency and reducing eye fatigue for all CAD/CAM users. By making the color contrast higher, every displayed line will be perfectly distinguished. With BenQ CAD/CAM monitor, you will never miss a line again in your designed work. -
Great color monitor with AHVA panel and 100% sRGB
With the BenQ's advanced AHVA panel and 100% sRGB screen technology, every color is delivered with the finest precision in every detail and at every possible viewing angle. Get and share a professional viewing experience. -
Present mode
Render on projector - let your monitor and projector talk to each other. Present mode simulates the color, contrast, and brightness of projectors for less difference between projector and monitor. Show off your design work in the color that you intended for excellent and precise presentations. -
Slim bezel for dual monitor setup
The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space. -
USB 3.0
2 x USB 3.0 ports on the side of the screen effortlessly bring all your content together in one convenient package. USB 3.0 provides super-speed data transmissions. -
Flicker-free
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but they can certainly feel them. Free your eyes from flickers by switch to CAD/CAM monitor and let your eyes do less work while you are working on CAD/CAM designs. -
Ergo monitor - HAS
An extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel - tailor your own unique working station that is best suited for your height and viewing habits with a maximum 150 mm distance between the screen bottom and the base. -
Reading mode
Corporate users are frequently required to read documents from a monitor. Reading mode adjusts the screen brightness, contrast ratio and sharpness to make your eyes feel as easy as reading directly from hard copies without wasting any paper. -
Eye protect sensor
Ambient light levels are automatically detected to help adjust the monitor brightness throughout the day for optimized clarity and viewing comfort. The smart reminder feature reminds you to take a break from staring into the computer screen at preset intervals of 20, 40, 60 and 100 minutes.
- BenQ BL2710PT - BL Series - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 52 kWh
- Power Consumption (On mode)
- 36 W
- Panel Type
- AHVA
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey), 12 ms (tr - tf)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 90 - 264 V (47 - 63 Hz)
- Black
- 63.9 cm x 25.9 cm x 39.7 cm
- 8.2 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- TUV GS, EN 60950, TUV Ergo, ISO 9241-307
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 52 kWh
- Diagonal Size
- 27"
- Panel Type
- AHVA
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, H/V position, sharpness, input select, colour temperature, phase
- HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Flicker Free technology, CAD/CAM Mode
- Black
- 8.2 kg
Audio
- Speakers - integrated
- Output Power / Channel
- 3 Watt
- VGA , DVI-D (HDCP) , DisplayPort , Headphones , Audio line-in , 2 x USB 2.0 , 2 x USB 3.0
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 36 W
- Power Consumption (Typical)
- 42 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- No
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years - on-site
- 5 °C
- 40 °C
- 20 - 90% (non-condensing)
