BenQ BL2710PT 27" 2560x1440 8ms VGA DVI HDMI USB Monitor Black
Quicklinx: 925RWS00 Mfr#: 9H.LAALB.QBE
Select:
  • 27"
BenQ BL2710, the first tailored CAD/CAM monitor is the ultimate solution carefully designed to meet all demands of every professional working with PTC, SolidWorks, AutoCAD, Maya or other CAD/CAM software.
  • CAD/CAM monitor - never miss a line again
    Featuring a 27" 2560 x 1440 WQHD Flicker-free screen, 100% sRGB, DP, HDMI and USB 3.0 ports, HAS with unique CAD/CAM mode, which easily handles work with complicated object wireframes, this CAD/CAM monitor is bringing you optimal and holistic experience that turns your job into enjoyment.
  • 27" big screen and 2560 x 1440 WQHD high resolution
    With a 2560 x 1440 WQHD resolution you can enjoy over 77% more work space and higher ppi compared to conventional 1920 x 1080 FHD monitors. Having the extra working space means less scrolls for zooming in and out, and the higher ppi gives you a sharper and more precise viewing experience.
  • CAD/CAM mode for precision design
    The unique CAD/CAM mode is specially designed to enhance work efficiency and reducing eye fatigue for all CAD/CAM users. By making the color contrast higher, every displayed line will be perfectly distinguished. With BenQ CAD/CAM monitor, you will never miss a line again in your designed work.
  • Great color monitor with AHVA panel and 100% sRGB
    With the BenQ's advanced AHVA panel and 100% sRGB screen technology, every color is delivered with the finest precision in every detail and at every possible viewing angle. Get and share a professional viewing experience.
  • Present mode
    Render on projector - let your monitor and projector talk to each other. Present mode simulates the color, contrast, and brightness of projectors for less difference between projector and monitor. Show off your design work in the color that you intended for excellent and precise presentations.
  • Slim bezel for dual monitor setup
    The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space.
  • USB 3.0
    2 x USB 3.0 ports on the side of the screen effortlessly bring all your content together in one convenient package. USB 3.0 provides super-speed data transmissions.
  • Flicker-free
    The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but they can certainly feel them. Free your eyes from flickers by switch to CAD/CAM monitor and let your eyes do less work while you are working on CAD/CAM designs.
  • Ergo monitor - HAS
    An extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel - tailor your own unique working station that is best suited for your height and viewing habits with a maximum 150 mm distance between the screen bottom and the base.
  • Reading mode
    Corporate users are frequently required to read documents from a monitor. Reading mode adjusts the screen brightness, contrast ratio and sharpness to make your eyes feel as easy as reading directly from hard copies without wasting any paper.
  • Eye protect sensor
    Ambient light levels are automatically detected to help adjust the monitor brightness throughout the day for optimized clarity and viewing comfort. The smart reminder feature reminds you to take a break from staring into the computer screen at preset intervals of 20, 40, 60 and 100 minutes.
BenQ BL2710PT - BL Series - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
36 W
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey), 12 ms (tr - tf)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
AC 90 - 264 V (47 - 63 Hz)
63.9 cm x 25.9 cm x 39.7 cm
8.2 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
TUV GS, EN 60950, TUV Ergo, ISO 9241-307
3-year warranty
Display Type
Energy Class
Class B
52 kWh
Diagonal Size
27"
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, H/V position, sharpness, input select, colour temperature, phase
HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Flicker Free technology, CAD/CAM Mode
8.2 kg
Audio
Speakers - integrated
Output Power / Channel
3 Watt
VGA , DVI-D (HDCP) , DisplayPort , Headphones , Audio line-in , 2 x USB 2.0 , 2 x USB 3.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
36 W
Power Consumption (Typical)
42 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - on-site
5 °C
20 - 90% (non-condensing)
