BenQ BL2423PT 24" 1920x1080 6ms DVI-D USB DisplayPort LED Monitor
Quicklinx: CNQVWS00 Mfr#: 9H.LFSLA.TBE
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: DVI, DisplayPort, VGA (HD-15)
£160.80 ex VAT
£192.96 inc VAT
BL2423PT is designed for eye-care comfort and enhances work productivity. Featuring the utmost image performance of a 8-bit premium IPS panel.
  • Enterprise-class image quality and ergonomic options for office comfort
    Featuring the utmost image performance of a 8-bit premium IPS panel. BL2423PT delivers 23.8" high-resolution corporate display capability with outstanding contrast, crisp clarity, and breathtaking color performance. Designed for ergonomic solutions and eye-care comfort, the BL2423PT monitor enhances work productivity. Energy efficient displays reduce your corporate's carbon footprint, encouraging corporate social responsibility.
  • Brightness Intelligence technology
    Intuitive B.I. tech. automatically balances the monitor's brightness, making it easier to focus on every detail in the highlights and shadows. It also adjusts the display's brightness and clarity depending on the ambient lighting, creating great images that are easy for your eyes to process.
  • Flicker-free
    Stable feedback technology prevents the harmful effects of flickering that strain the eyes.
  • Low Blue Light
    Unique BenQ Low Blue Light technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation.
  • Height adjustment stand
    The HAS allows you to find the best viewing angles for personal work or screen sharing with an extensive range of monitor adjustments.
BenQ BL2423PT - BL Series - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
56.32 cm x 7.15 cm x 33.87 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology
4.1 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Security Slot Type
Kensington security slot
Power Consumption (Typical)
16 Watt
Power Consumption (Off Mode)
0.5 Watt
Apple MacOS, Microsoft Windows 7, Windows 8, Windows 10
Sustainability Information
ENERGY STAR Certified
Response Time: 6ms
Interfaces: DVI
Interfaces: DisplayPort
Interfaces: VGA (HD-15)
Brand: BenQ
