Build with an LED backlight panel, the stylish BL2405HT comes with an ultra-high dynamic contrast ratio of 120,000:1, 16:9 100% dot-to-dot image quality, and BenQ's exclusive Flicker-free technology and Low Blue Light mode to offer you the best viewing quality at all times.
The BenQ BL series is designed with computer ergonomics in mind to add comfort and flexibility to your everyday work - boosting productivity and efficiency at the same time! Designed for business environments, the BenQ BL series of professional monitors is an essential part of your solutions to minimize total cost of ownership and maximize staff productivity - a win-win decision for the benefits of all.
A win-win decision for mutual benefits
The BenQ BL series is designed with computer ergonomics in mind to add comfort and flexibility to your everyday work - boosting productivity and efficiency at the same time! Designed for business environments, the BenQ BL series of professional monitors is an essential part of your solutions to minimize total cost of ownership and maximize staff productivity - a win-win decision for the benefits of all. -
Flicker-free backlight for visual pleasure
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but can certainly feel them. Free your eyes from flickers by switching to Flicker-free monitors and let your eyes do less work. -
Low Blue Light mode
Every monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset Low Blue Light modes from OSD hot key and reward your eyes without having to lose the visual enjoyment. -
Height adjustment stand (HAS)
The HAS allows you to find the best viewing angles for personal work or screen sharing with an extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel. The screen bottom can be 110 mm from the base. -
12M:1 DCR for depth and definition
The BL2405HT comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. -
ecoFACTS label
ecoFACTS can tell you how eco-friendly BenQ products are! Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products.
- BenQ BL2405HT - BL Series - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 24 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray), 5 ms (tr - tf)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), tilt
- Voltage
- AC 120/230 V (47 - 63 Hz)
- 57.9 cm x 21.3 cm x 50.2 cm
- 5.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, ISO 9241-307
- Display Type
- Energy Class
- Class A
- 35 kWh
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 76 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, sharpness, colour temperature, phase
- HDCP, Senseye 3 Technology, EyeCare Utility, Ultra-Flexible Height Adjustment System (HAS)
- 57.9 cm x 21.3 cm x 50.2 cm - with stand
- 5.1 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
- Tilt Angle
- -5/+15
- Swivel Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 24 W
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.3 Watt
- On / Off Switch
- No
Sustainability Information
- ENERGY STAR Certified
