Designed for beautiful simplicity, BenQ's BL2283 21.5" frameless monitor combines ultra slim bezels with hidden cable management. Complementing BenQ's exclusive Eye-Care Technology with Low Blue Light Technology and Flicker-Free performance for extended viewing comfort, the industry-leading Brightness Intelligence Technology delivers exquisite details in any ambient lighting environment. Built with the dream combination of LED with IPS panel, BL2283 is bound to bring a whole new visual experience and enjoyment to you with truly authentic colors, deeper blacks, higher contrast and sharper details.
Understated, stylish and sophisticated design
BL2283 comes with a stylish and sophisticated design that boasts an elevated level of elegance while helping to enhance the overall productivity. Empowered by the premium etching texture and sculpted base, BL2283 resists fine scratch whirls and eliminates extraneous edges for a clean, functional appeal. Additionally, the edge-to-edge panel with ultra slim bezels can complement any modern décor. To ensure the cleanest look, BL2283 offers an invisible cable management system to neatly hide all wires inside the monitor's stand. -
IPS wide-viewing-angle technology
IPS (In-Plane Switching) technology provides accurate color and image reproduction from any angle. An expansive 178° viewing angle is ideal for work and for on-screen reviews with multiple people in the room. -
8-bit color display
With the ability to render 16.7 million color shades simultaneously, you can expect true colors, silky transitions and impeccable image quality. -
BenQ's exclusive eye-vare technology
BenQ's exclusive eye-care technologies reduce eye fatigue for user comfort, enhanced productivity, and workplace safety during extended use.
- BenQ BL2283 - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class F
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 17.7 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- 2xHDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- 48.95 cm x 18.3 cm x 39.16 cm
- 2.9 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- TUV Rheinland, HDCP 1.4
- Display Type
- Energy Class
- Class F
- 28 kWh
- Diagonal Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Per Inch
- 102
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, Advanced Motion Accelerator (AMA) technology, Low Blue Light Mode, Flicker Free technology, Ultra Slim Design Bezel, Eye-Care Technology, Brightness Intelligence Technology, 72% NTSC colour gamut
- Black
- 2.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- VGA , 2 x HDMI , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Input Voltage
- AC 120/230 V
- 17.7 W
- Power Consumption SDR (On mode)
- 17.7 kWh/1000h
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.5 Watt
- Shipping Weight
- 3.7 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
