BenQ BL2205PT 21.5" 1920x1080 2ms DVI DP LED Monitor with Speaker
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: BPGSWS00 Mfr#: 9H.LE9LA.TBE
Select:
  • 22"
With the right help, even work can be more enjoyable and fulfilling. Designed with ergonomic features to boost your work comfort and productivity, the BL2205PT is the winning choice for any workstation.
BenQ BL2205PT - BL Series - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray), 5 ms (tr - tf)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Non-glossy black
51 cm x 21.4 cm x 47.4 cm
5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Low Blue Light Mode, Ultra-Flexible Height Adjustment System (HAS), 72% NTSC colour gamut
Non-glossy black
51 cm x 21.4 cm x 47.4 cm - with stand
5 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI , DisplayPort , VGA , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Flicker-free technology
1 x VGA cable - 1.5 m
Security Slot Type
Kensington security slot
Power Consumption (Typical)
21 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 51 cm - depth: 21.4 cm - height: 47.4 cm - weight: 5 kg , Without stand - width: 51 cm - depth: 5.04 cm - height: 30.2 cm
Sustainability Information
ENERGY STAR Certified
BPGS C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
