BenQ BL2205PT 21.5" 1920x1080 2ms DVI DP LED Monitor with Speaker
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: BPGSWS00 Mfr#: 9H.LE9LA.TBE
Select:
  • 22"
With the right help, even work can be more enjoyable and fulfilling. Designed with ergonomic features to boost your work comfort and productivity, the BL2205PT is the winning choice for any workstation.
  • Ergonomic design
    With height, pivot, swivel, and tilt adjustments, the BenQ BL2205PT offers a flexible height adjustment system (HAS) that ensures optimal ergonomics for extended use.
  • Vivid visuals
    Experience the brilliance of 16.7 million colors and a 72% NTSC color gamut on a 21.5-inch Full HD 1080p display, enhanced with an anti-glare coating for reduced eye strain.
  • Seamless connectivity
    Equipped with DVI, DisplayPort, and VGA interfaces, this LED-backlit LCD monitor offers versatile connectivity options for both legacy and modern devices.
  • Enhanced productivity
    Features like Low Blue Light Mode and Flicker-Free technology work to reduce eye fatigue, allowing for longer periods of productivity without discomfort.
  • Efficient performance
    The BenQ BL2205PT is ENERGY STAR certified, ensuring energy efficiency with a typical power consumption of just 21 W, making it an eco-friendly choice for your workspace.
BenQ BL2205PT - BL Series - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray), 5 ms (tr - tf)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Non-glossy black
51 cm x 21.4 cm x 47.4 cm
5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Low Blue Light Mode, Ultra-Flexible Height Adjustment System (HAS), 72% NTSC colour gamut
Non-glossy black
51 cm x 21.4 cm x 47.4 cm - with stand
5 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI , DisplayPort , VGA , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Flicker-free technology
1 x VGA cable - 1.5 m
Security Slot Type
Kensington security slot
Power Consumption (Typical)
21 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 51 cm - depth: 21.4 cm - height: 47.4 cm - weight: 5 kg , Without stand - width: 51 cm - depth: 5.04 cm - height: 30.2 cm
Sustainability Information
ENERGY STAR Certified
BPGS C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £17.38
BPGS C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £11.25
BPGS C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £14.05
